Issues With The Roof: Loud Thud & Drop When Opening The Roof
BMWStyle326M
 Singapore
Hello to fellow members, I have a 2009 BMW E89 Z4 sDrive30i.
I have an issue when opening the hard top roof. When the back piece comes on to the top piece there seems to be a loud thud and looks quite rough. Has anyone faced this issue and what could most likely be the issue?
Thanks in advance, any help is very much appreciated.
The roof support damper strut has weakened / failed ..not the boot lid strut.. needs some ingenuity or the BMW special tool to fit a new pair of struts..with the tool its a simple job..
Hihi, thanks for the swift reply. Do you happen to know which is the strut responsible?
Is it No.2, No.3 or No.4 in the photo below?
No idea at the moment.
I've placed it into the German ZRoadster forum to be discussed as well. Up to now lot's of AI nonsense as response. :D
This is the spring on both sides of the front roof shell, responsible for a bit of damping of the rear roof shell:
  • Wow
Maybe you'll check at first, if it is available at all or even broken.
The front headlining has to be removed to get an insight into this mechanism.
