E86 Tube leaking - Help identifying it?
samueld1135
 Edinburgh
Hi all,
Noticed that this small white tube (highlighted in red in the images) near the engine can sometimes leak. Looking at it, it seems like it’s got a few kinks and possibly a crack at the bottom I can’t see. Noticed when it started letting out small amounts of white smoke every now and again. Considering this I believe it’s likely a coolant line or maybe water? Despite this coolant levels don’t seem to reduce much, and the engine never overheats.
I just can’t figure out what it is, and was wondering if anyone else may know so I can get it replaced. Any help would be greatly appreciated. (And I’m praying this isn’t a too expensive fix)
Thanks,
Those are electrical lines
Your leak will be oil escaping from the valve cover- needs a new gasket. It drops down onto the hot exhaust below
Hey thanks for the timely response. I was worried it could be this, but the oil levels never seem to depreciate much either. Would they actually reduce or is it more a drop wise things typically?
