Your specialist subject: life and times of Android display screen as part of or in place of BMW CIC
B21
Elite
 Scottish Borders
Background
I’ve looked at these alternative screens to the normal idrive display..there are two key versions..some are Linux based and the majority Android based.
The Linux ones offer little extra functionality but improve the quality of the display.
The Android units are self contained fully functional units.
My arguments against them were:
Ruins the charm of the flip up screen
Very poor audio quality
I can do most things with CIC and a MMI box doing CarPlay.
However…
Now I’ve recovered the dash the little idrive unit looks a bit out of place /tired..I could maybe get it recovered to match..
The new ID4Motion screen and graphics makes the idrive look dull and a bit chunky…it looked great with the standard cluster ..a bit steam punk ish..!
The sound issue really was my big issue….all the units only (on E89s) output sound via Android on board sound via 3.5mm plug to the BMW aux in socket..with its own acoustic limitations..having spent £3k getting pretty close to audio perfection and unacceptable compromise..
I thought I had solved this as being Android based I could get it to Bluetooth out to an optional Audiotec Fischer Match Bluetooth HD card that could be added to my Match 10 DSP/amp…
Sadly it turns out that the Bluetooth out chip set is missing on these designs..you can Bluetooth in so you can play your phone into the head unit but not send Bluetooth audio out.
So I cancelled my order.
However..a bit more research showed that all Android units after V8 support USB sound out.
Reading the very sad bunnies on the F30 forums who had gone to extraordinary lengths to play with these units it transpired that several folks had plugged a DAC into one of the head units USB socket and got high quality audio to come out ..into the DAC and then via a 3.5mm plug into the BMW sound system via aux.
This still has the crappy BMW aux issue…but..in my case I have my beloved and expensive Match 10 DSP/amp.
I’m not using the ‘normal’ analogue inputs as my car is a 677 with the digital fibre optic MOST bus so my audio is routed via a MOST adapter to the TOS optical input in the amp.
The voltage levels from the DAC..I had an AudioQuest DragonFly Black lying around ..were maybe not perfect..some people feeding it into the BMW aux complained about noise..but I thought since I can adjust input gain maybe I can get it to work.
Then I realised that the harness pre-made for the 677 amp was going to need some re-pinning ..
However the AF products all support one or in some cases two additional interface cards.
They do a high quality aux card at the spot on voltage levels..so getting closer.
Then the epiphany…the AF guys do a USB card as well..this talks to an android device as a pseudo speaker..and voila..
We can go pure digital direct from the Android display unit to the DSP / amp..all at ridiculously good data rates and bit depths.
So I’ve reordered the unit..will ger at a Match MEC USB interface card and a long (4m) usb cable ..it should work!
There are dozens of Chinese suppliers and UK shops offering them..there are probably about 10 real manufacturers which all look similar but when you start to dig then differences appear.
These guys have offered good technical support, product quality seems good, they make their own version..
What could possibly go wrong?
It’s probably a winter project to get it fully workimg..may be able to Jerry rig it to act just an idrive display sooner.
Well my first attempt didn’t go too well..
The unit was lovely ..but..it was way too big for the cabin of an E89..
Fortunately the seller was happy to accept a return bar import fees..
Any progress on this project?
Have a stuck cic screen :( , luckily in the open position. Considering an upgrade as well.
In a way, it’s a shame you can’t retrofit the NBT EVO 8.8 screen to them E89 screen aperture. Car play and there Android definitely work better with touch screen….probabky need used screen from a scrapped car to take apart and see if it can be refrofitted. I wonder if the touch aspect is in the screen electronics or in the head unit…. The mystery continues
I’m about to fit the 10.5” HiFi Max Android screen in the next couple of weeks..still trying to loosen of all the rusty brake lines and associated parts..
I’ve set up a test rig on the bench and it seems to work well..
NBT uses a different video format to drive the screen to CIC so it’s a show stopper..
I hate touch screens with a vengeance in cars / aircraft etc..really oisses me off fingerprints..
Much prefer idrive controller…
Plus the screen is too far away for a comfortable reach to touch..do you’d be not sat properly whilst farting around ..not good hooning away..
So apart from those points ..great idea ! :tumbleweed: :rofl:
Maybe a bit offtopic but checked the display to find out some broken plastic parts from the screen blocked the gears. No clue why they broke. Removed the bits and pieces, cleaned up the plastic parts, and re-greased the gears. Working fine again….
Looking at a replacement android screen myself too, bu5 I have a question.. do any of the screens still support the pop up action and flip down? Would be kinda a shame to loose that?
Do any of the Ali express z4 e89 radios allow you the access to the stuff you can pull up on the oem radio? Ie car stats/oil level and all that? Again appologies for being a newbie.. oh and what’s the difference between CIC and the other NBT one?
No yes no
Cic was fitted to E89.. car information computer
NBT next best thing was its successor fitted to F series
No you can’t retrofit NBT
Following with interest as my first mod will be to fit an infotainment screen, main requirement is the I drive control (same reason as B21) and a screen that fits in the sale postion as the storage cupboard its replacing, lots Ive seen are to big and land over the edges which doesnt look good in my eyes
One below would be perfect depending on spec, anyone got a link to it : Ignore found it. what other options besides HifiMax that includes the Idrive? always good to have a comparison before ordering
There are dozens of vendors offering either the same or very similar versions ..Hi Fi Max ugode have better known reputations.. if you're using to run car play android auto (my recommendation) then I guess cheaper may be cost effective..I'd avoid the 12.3 " monsters and get one with a pseudo i drive controller ..touch is a big no..
Agree with you, have to have an idrive, i was looking at prices in dollars, not too bad in uk money compared with the one i bought for my z4 7 years ago and that didn’t have CarPlay, and the one in the photo sits properly in the space rather overhangs . Dave fitted my last one along with cruise control so might wait till he’s back in action as don’t trust some of the places round me to do a good job
Yeah I've seen it in thier vid. Your 12 inch review pic gave a much better indication though.
