Went down an AI rabbit hole with datalogs
Envain
 Berkeley, Ca
So this started innocently enough. I've been running MHD on my E89 for a while now and started pulling datalogs more regularly. Figured I'd run them through Claude to get some interpretation since staring at CSVs isn't exactly my strong suit.
The AI was extremely thorough. Maybe too thorough.
From MHD logs:
  • LTFT running at 14–18% on both banks
  • Cyl timing correction showing -3° to -8° across all 6 cylinders
  • Knock events at light load/cruise constantly
From BimmerLink:
  • Ignition timing Cyl 1 median: 1.5° BTDC (was 20-21° previously)
  • Knock voltage Cyl 3 and 6 max: 4.39V (baseline was ~0.55V at idle)
  • Uneven running Cyl 3: -4698 to +3357 µs
  • Uneven running Cyl 6: -1260 to +4707 µs
  • Lifetime misfire counters: Cyl 3 at 403, Cyl 4 at 308, Cyl 2 at 249
The reassuring stuff:
BimmerLink also showed:
  • LTFT actually 3% (the MHD 14% was a misread — apparently the INA0S tune custom tables confuse MHD)
  • Lambda 1.01 — perfect across multiple drives and conditions
  • Leakage adaptation -1.75 kg/h — no vacuum leak
  • At a actual WOT boost moment: timing correction was 0°
For context, the car drives absolutely perfectly. No limp mode, no CEL, no rough idle, no power loss, pulls hard, boosts clean. I've been doing canyon runs with no issues whatsoever. Before I started logging, I had zero concerns about this car.
Should I trust any of these numbers or is this a case of having data without the context to interpret it properly? Has anyone else run their N54 logs through AI and ended up spiraling like this? Are these BimmerLink values (knock voltage, uneven running ranges, misfire counters) actually saying something meaningful or is this just normal N54 behavior that looks scary on paper?
Curious what you guys think.
We have the classical cyl 6 misfire on a tuned N54…my tuner (brain the size of a planet) theorised about the issues…
Separately much much later tipped the datalogs into Claude…all over it like a rash…spotted and modelled the exact sequence ..very very spooky…
Claude on opus 4.7 etc very very powerful…
From MHD logs:
From BimmerLink:
Interesting stuff. How are you logging the data? If I wanted to do something similar are there logs already in the car's control units or do you need a separate solution to read the cars parameters and create the logs?
I've been using a mix of the MHD flasher app and Bimmerlink. Bimmerlink seems the better of the two for sensor data. Looks like the ECU caches some data like misfire count. Both apps let you manually record or set up automatic logging (MHD), but auto didn't work for me, so I'll just start/stop when I want to run the data through Claude. Plus they have a dashboard so you can view the data as you do your thing.
Well, sick Fable on it and see what it says... when they let it back out of federal prison....
Honestly hadn't thought of that yet, but now I'm probably going to start a project on cowork and start logging. :headbang:
What did Claudio infer from your data? Please keep the thread updated as you explore.
Lol... don't even get me started..the fix I think, was a step colder spark plugs gapped at .022 at least from what it says. The previous ones were off Amazon so maybe a fake NGK?
Still fun to run these logs through with a large grain of salt.
