Hi all
Not seen this before so looking for guidance
Replaced the expansion tank as it was showing dribbles. Car wasn’t overheating and got up to temp fine so assume the pump is good.
Done- go to start bleeding via the car- won’t initiate.
Use inpa- says it’s bleeding but it isn’t.
Check for codes and the car shows 2E84 with no MIL. That’s like a BMS code for comms as I read it. Code is persistent won’t disappear.
Checked the wiring and it’s, well, crispy. See pics. Plugs were clean but I used contact cleaner just in case.
Questions-
Can I bleed the car in the standard way you’d bleed an M54 with the engine running?
Should I replace the green wiring?
Anyone else experienced this at all?
Cheers in advance
Stuart
Questions-
Cheers in advance
Stuart
