Hi all
My z4’s been off the road for the last few months owing to the well-known power steering motor/module failure. Fault was intermittent to start with but now permanent, with sport button also dead. I plan to work on this over the next couple of weeks.
The driver’s seat is out and lower trim is removed. Having had a good look at the column, I’m now in desperate need of some guidance on best procedure to follow from here, if anyone can help? Photos attached below.
I think I understand the basic process - loosen the eight bolts holding the steering column brackets to drop the column slightly, unplug electrics, mark alignment of the motor/steering column/spacer, remove the two torx bolts securing the motor to free the motor and send off for repair. But I have a few question on points where previous threads seem to give conflicting advice.
- do I need to remove the steering wheel and/or remaining lower trim? As far as I can see, the lower dash part that would actually be helpful to remove is not removable. Does the steering wheel shroud need to come off?
- do I just loosen the 8 bolts holding the steering column brackets, or do some of them need to be removed? How far to loosen?
- after loosening the brackets, do I have to rotate the column/motor 90 degrees so that the motor is pointing down? I cannot see how there is space for this. Equally I cannot see how there is space to remove the motor without doing this. Does the narrow horizontal piece of trim in the first photo need to come out?
