Underpowered N52 2.5i - upgraded to 2.5Si
Hi zedebee just came across this thread, I’m struggling to find the correct manifold with those part numbers? Any help would be greatly appreciated
what do you need help with - the right part numbers, or finding a manifold? I am pretty sure that any N52 manifold with the second DISA valve will work. If you are buying off eBay, make sure you can see the second DISA, as I have seen plenty of adverts with pictures taken at dodgy angles to obscure the fact there is only one.
Hi Walker,
Try to buy the manifold and disa valves together. If you buy separately you probably won’t have the 3 small mounting bolts for the additional disa valve. These are expensive! Around £13 iirc. Ask me how I know.
I’m looking for the manifold, had a look on eBay with that part number but not sure if any are the correct one as I can only see one valve on the pictures
Rbm thanks for the tip, I was trying to buy it all together as it is, just easier isn’t it
Reactions: RMB
I bought one from eBay which I think was for an E60
It worked a treat with some minor fettling of the ccv system
Am in the process of assembling the gear. Sadly, my cheap manifold did not come with the valves. Going to use the main one from my car, and an eBay special for the second smaller one. But the bolts!!!
I have a manifold from a 2.5 because part numbers were different to the 3.0
I hope this is for the pair and not each...
Will be using Cotswold, but still...
Sadly, that will be each.
