LL-01 Oil Available in USA Market
tkvoice
 Minnesota
I am a new owner of 2003 Z4 2.5i with 5-speed manual. I live in Minnesota.
I am looking to do an oil change but I am having trouble finding correct oil to purchase.
Research leads me to believe I should be looking for 5W30 or 5W40 full synthetic certified for BMW LL-01
I can find few brands with LL-04 but LL-01 is rare
Is LL-01 a must have?
What oil do other users recommend?
Is there anything I can buy at the local Walmart?
I did find 1 so far:
Quaker State Euro Full Synthetic 5w40 has LL-01 (online order only)
LL-04 was the 2004 replacement for LL-01 so buy that. There was even an LL-99 but it was almost completely unknown.
TBH, I'm not even sure if was very relevant to petrol engines (it was more a Diesel thing) - the M54 has a lineage back through the 90s when manufacturer specs weren't really a thing.
I Asked CoPilot if LL-04 is backward compatible with LL-01. It's telling me not in MN .... AI is known for getting things wrong... But did it get this right?
Co Pilot answer follows:
Short answer: Yes, BMW Longlife‑04 (LL‑04) is technically backward‑compatible with LL‑01, but only under specific fuel‑quality conditions.
In the U.S. (including Minnesota), LL‑04 is not recommended as a replacement for LL‑01 in gasoline engines unless BMW explicitly allows it.
🔧 What the sources say
- LL‑04 was designed as a low‑SAPS oil for diesel engines with DPFs, and BMW permits it for gasoline engines only in regions with consistently low‑sulfur fuel (EU, Switzerland, Norway, Liechtenstein).
- Outside those regions, BMW requires LL‑01 for gasoline engines, because higher‑sulfur fuel can cause LL‑04 to degrade faster, leading to oil dilution and shortened intervals.
- LL‑04 does cover older BMW specs including LL‑01 from a technical standpoint, but BMW’s own guidance restricts its use in gasoline engines based on fuel sulfur content.
- Community and expert discussions confirm the same: LL‑04 is fine for gasoline engines only where low‑sulfur fuel is guaranteed; otherwise LL‑01 is the correct spec.
🧩 Why compatibility depends on fuel sulfur
- LL‑04’s low‑SAPS formula protects particulate filters but has lower TBN, meaning it neutralizes acids less effectively.
- High‑sulfur gasoline (common outside the EU) produces more acidic byproducts, which can cause LL‑04 to break down faster.
- This is why BMW restricts LL‑04 for gasoline engines in markets like the U.S.
🇺🇸 What this means for you in Minnesota
- U.S. gasoline sulfur levels have improved, but BMW still specifies LL‑01 for most U.S. gasoline engines.
- Using LL‑04 won’t instantly harm the engine, but it may shorten oil life and is not BMW‑approved for U.S. gasoline models unless your manual explicitly lists LL‑04.
✔️ Bottom line
- LL‑04 is backward‑compatible with LL‑01 only in regions with low‑sulfur fuel.
- In the U.S., including Minnesota, LL‑01 remains the correct and approved spec for gasoline engines.
- If your BMW is diesel with a DPF, LL‑04 is the correct choice everywhere.
I use Castrol Edge "Euro Car" it meets the BMW LL-01 spec.
Well, that's a new one on me. A quick google (far more sensible than pissing around with LLMs) shows many discussion threads saying just this.
The M54 is barely any different to the M52 that came out in 1995, long before low anything oil came along. We were still using boggo semi-synthetic 10w40 back then so I'd just buy a standard synthetic (or semi-synth!) 5w30 or 5w40 that you'd throw in anything and not worry about it.
The original owners manual doesn't even say what SAE viscosity to use. How do we know 5w-30 or 5w-40 is correct?
and why not use 0w-30 or 0w-40? as the "0w-XX" variants seem to be more readily available
I always went with the widest viscosity band, but never starting any lower than 5 on higher mileage BMWs.
Here is my two penny worth.. (3 cents)
Why the owner's manual is silent​
You're right that the early E89 owner's manual is unhelpful. BMW's deliberate position from roughly 2005 onwards was that the approval (BMW Long Life rating) was the specification, and the SAE viscosity grade was a secondary detail handled by the approval list. The thinking was:
  • SAE viscosity alone tells you nothing about whether an oil is suitable for a BMW engine — a 5W-40 from a supermarket and a 5W-40 LL-01 are radically different oils
  • An LL-01 oil has been tested, approved, and is therefore safe in any BMW engine that calls for LL-01, regardless of viscosity grade
  • Quoting a viscosity in the manual would mislead owners into thinking SAE grade was the relevant filter
This was technically defensible but unhelpful for owners. The actual answer for the N52 is BMW LL-01 in either 5W-30 or 5W-40, with a regional bias that explains the US confusion.
Why US N52 owners see 5W-30 dominantly​
In the US market, BMW's dealer fill for N52s from around 2007 onwards was Castrol Edge 5W-30 (LL-01), sometimes branded as "BMW High Performance 5W-30" with BMW packaging on the same Castrol product. This wasn't because 5W-30 was the only correct grade — it was because:
  1. BMW negotiated a contract with Castrol for one grade across most of their petrol fleet for fleet logistics simplicity
  2. 5W-30 met the LL-01 requirement and was a slightly more fuel-economy-friendly grade for CAFE compliance
  3. Bulk dispensing at dealerships meant one barrel for everything
European-market N52s often saw 5W-40 LL-01 dealer fill (Shell Helix Ultra was common). Same engine, different default grade, both correct.
So the US "5W-30 must be right" instinct comes from dealer fill conformity, not from a technical specification that excludes 5W-40.
Why 5W-40 is also correct (and arguably better)​
The N52 is BMW's magnesium-alloy block engine, and that's the technically interesting bit. The block uses an AJ62 magnesium alloy with aluminium cylinder bore inserts. Magnesium and aluminium have different thermal expansion coefficients, which means:
  • Bearing clearances change measurably across the operating temperature range
  • The crankcase grows slightly faster than the bore liners as it heats up
  • Oil film thickness needs to be adequate across a wider operating clearance window than in a conventional all-aluminium block
A 5W-40 gives you slightly more film thickness at sustained operating temperature than a 5W-30 — useful margin for an engine that asks more of its oil than its all-aluminium siblings, particularly in summer heat or sustained highway running. The N52 is also a high-revving naturally aspirated engine that holds high oil temperatures for longer than a turbo engine on the same drive cycle (turbo engines spend less time at peak load; NA engines often cruise at higher RPM continuously).
For a US N52 owner driving in Texas summer heat, 5W-40 LL-01 is the technically more conservative choice even though 5W-30 was the dealer fill. For a Boston driver doing mostly city miles, 5W-30 is genuinely fine.
Why not 0W-30 or 0W-40?​
Three things to understand:
1. The "W" number is the cold-flow rating, not just availability. 0W-XX oils flow at lower temperatures than 5W-XX oils. The "0W" rating means the oil pumps cleanly at -35°C; "5W" pumps cleanly at -30°C. Both are well below any temperature at which an N52 would be started in normal use anywhere in the lower 48 US states.
2. Achieving the 0W cold rating means more polymer thickeners. This is the technical catch most owners miss. A 0W-40 oil has to start as a thinner base oil than a 5W-40 (to pass the cold flow test) and then be thickened back up to grade-40 viscosity at operating temperature using viscosity index improvers (VII). Those polymers shear over time and miles, meaning the oil's effective viscosity drops as the OCI progresses. A 5W-40 of the same base-oil quality needs less VII thickening, shears less, and stays closer to its label viscosity through the change interval.
For a fleet of cars in Anchorage, the cold-flow benefit of 0W-40 outweighs the shear concern. For Phoenix, you've added shear susceptibility to gain cold-flow performance you'll never use.
3. Some 0W oils are LL-01 approved; many aren't. Mobil 1 0W-40 (the famous "European Car Formula" with the silver bottle) is BMW LL-01 approved and is genuinely a fine oil for an N52. Castrol Edge 0W-40 is also LL-01 approved in some markets. Other 0W-40s on US shelves carry only API SP / ILSAC ratings without LL-01, which means they haven't been tested against BMW's specific durability requirements.
The practical answer for the question "why not 0W-XX":
  • 0W-40 LL-01 (e.g. Mobil 1 European Car Formula): perfectly fine, slightly more VII shear than a 5W-40 LL-01 over a long OCI but otherwise excellent. Particularly good if winters get cold.
  • 0W-30 LL-01: harder to find, less common, no real benefit over 5W-30 LL-01 in any US climate where an N52 would be started
  • 0W-XX without LL-01: avoid regardless of cold-flow advantage; the missing approval matters more than the W number
What the US N52 owner should actually run​
The honest hierarchy for normal US driving conditions (temperatures from -10°C to +40°C):
ClimateRecommendedReasoning
Hot southern states (TX, AZ, FL, southern CA)5W-40 LL-01Higher operating-temp viscosity margin. Castrol Edge 0W-40 or 5W-40 LL-01, Liqui Moly Top Tec 4200
Temperate (NC, VA, much of CA, OR)5W-30 LL-01 or 5W-40 LL-01Either is genuinely fine. Pick on availability and price
Cold winter states (MN, WI, ME, MT, AK)0W-40 LL-01Genuine cold-flow benefit, shear penalty is acceptable on annual changes
Track or sustained high load5W-40 LL-01 with shorter OCIOperating-temperature margin matters more than cold flow
A specific note on N52 oil consumption​
The N52 has a known tendency to consume oil — the valve-stem seals harden with age, the crankcase ventilation system can develop leaks, and the magnesium block's gasket interfaces (oil filter housing especially) seep with age. A 5W-40 can mask this because the thicker oil at operating temperature consumes slightly more slowly than a 5W-30 in the same engine. Some N52 owners find consumption drops noticeably switching from 5W-30 to 5W-40 — this is real and is one of the strongest practical arguments for 5W-40 on a higher-mileage US N52.
If a US N52 is consuming a quart between changes on 5W-30, switching to 5W-40 LL-01 may reduce that to half a quart without any other intervention. Worth knowing.
How would a US owner know any of this?​
The straightforward answer: by reading the BMW LL-01 approval list maintained by BMW Group, which includes both 5W-30 and 5W-40 oils. The owner's manual being silent on grade is BMW saying "any approved oil works"; the dealer fill being 5W-30 is fleet logistics, not a technical mandate.
For someone unwilling to dive into the spec lists, the safe heuristic is:
  1. Pick BMW LL-01 approval as the non-negotiable filter
  2. Pick 5W-30 or 5W-40 based on climate and use (5W-40 for hot climates, towing, mountains, high mileage; 5W-30 for moderate climates and city driving)
  3. Avoid 0W-XX unless winters are genuinely cold, in which case 0W-40 LL-01 specifically
  4. Change at 5,000–7,500 miles regardless of what the iDrive service light says — BMW's long-life intervals were optimistic and N52s suffer for them at 15,000-mile intervals
Should the book series cover this?​
Yes — and it's a good reason to add a short US-specific oil-strategy section in V2 (Maintaining). The European/UK perspective in the existing book content is correct for European cars, but US owners face a genuinely different situation:
  • Different dealer fill conventions (5W-30 universally vs grade-flexibility in Europe)
  • Different climate range (Phoenix to Anchorage covers more ground than Lisbon to Helsinki)
  • Different oil availability (Mobil 1 0W-40 European Car Formula is the dominant LL-01 oil in the US, where in the UK it's one option among many)
  • Different attitude to manual silence — US owners typically default to "follow the dealer fill" which produces the 5W-30 default that may not be ideal in their actual climate
A 1–2 page US oil-strategy callout in V2 would land well with American buyers and is the kind of regional sensitivity that distinguishes a definitive reference from a UK-centric book wearing a global title.
Want me to draft that callout for V2 inclusion? It would slot naturally into the existing engine-oil chapter and references both the "what BMW says" and "what actually works in your climate" angles.
Great summary !
I have used both the 5W-40 or Mobil 1 0W-40 strategies in a series of BMW's (not all at one time ;)). But I've always stuck to a 5K mile oil change interval.
I think the auto manufacturers have mastered the art of marketing their products for maximum profit. Yes there are probably some truths to "oil formulas" but I bet there are many off the shelf synthetic oils sold at Walmart that probably meet and exceed the BMW LL-01 requirements. The problem is that the oil companies need to pay big $ to get the LL-01 certified label and if the market doesn't justify this expense, they don't bother.
I think s_morris12 in his post above proves the point in the way he deals with oil changes. Might even be the better approach for US market as fuel type being burned in the engine probably has the most impact on oil life than any other factors. Maybe US BMW owners should just use DEXOS certified oil as this is definitely made to handle US gasoline blends.
17282.jpg17283.jpgI was able to find this online at Walmart and it wasn't much more than the full synthetic oil they had on the shelf
This is from BMW TIS;
Home / BMW E85 Z4 3.0i Roadster / Repair Manuals and Technical Data / 00 Maintenance and general note /
4.0 BMW Longlife-01​
BMW Longlife-01 engine oils are a minimum requirement for all BMW Group petrol engines without petrol particulate filter from model year 2002 and for BMW Group diesel engines without particulate filter from model year 2003. Aside from that, BMW Longlife-01 engine oils are also permitted for use in older BMW Group engines.
Refer to the document "Technically appropriate engine oils for BMW Group engines" for detailed release information.
Product availability may vary depending on specific market.
1.0 General information
3.0 Technically suitable engine oils for BMW Group engines
Please order from www.markethub.shell.com or contact your local Shell partner.
TU = trade unit. TU numbers cannot be ordered! Only for invoicing purposes!
Only in Saudi Arabia
Only in Japan
Only in South Korea
Canada only
Only in Malaysia
MINI Engine Oil LL-01 5W-30 SAE 5W-30
83 21 2 406 986**
MINI Original Engine Oil LL-01 5W-301 litre
[th]
Trade name​
[/th][th]
BMW part number​
[/th][th]
Container​
[/th]​
BMW Engine Oil LL01 5W30 SAE 5W-30
83 21 2 405 947**
BMW TwinPower Turbo LL-01 5W-301 litre
BMW TwinPower Turbo LL-01 5W-305 litre
[th]
Trade name​
[/th][th]
BMW part number​
[/th][th]
Container​
[/th]​
83 21 2 405 947**
BMW GROUP LL-01 5W-301 litre
BMW GROUP LL-01 5W-301000 litres IBC
BMW GROUP LL-01 5W-3020 litre
BMW GROUP LL-01 5W-30200 litre
BMW GROUP LL-01 5W-30209 litre
BMW GROUP LL-01 5W-30Fuel tank
[th]
Trade name​
[/th][th]
BMW part number​
[/th][th]
Container​
[/th]​
Named approved oils
8100 X-cessSAE 5W-30MOTUL
8100 X-cess GEN2SAE 5W-40MOTUL
8100 X-maxSAE 0W-30MOTUL
8100 X-maxSAE 0W-40MOTUL
AVIATICON Unique MDSAE 5W-40Finke Mineralölwerk GmbH
AVISTA pace EVO GERSAE 5W-40AVISTA OIL Deutschland GmbH
Aral HighTronic MSAE 5W-40Aral AG
Aral SuperTronic GSAE 0W-40Aral AG
BP Super V PlusSAE 5W-40BP PLC
BP Visco 5000SAE 5W-40BP PLC
Castrol EC PerformanceSAE 0W-40Castrol Limited
Castrol EC PerformanceSAE 5W-40Castrol Limited
Castrol Edge 0W-30 A3/B4SAE 0W-30Castrol Limited
Castrol EDGE 0W-40 A3/B4SAE 0W-40Castrol Limited
Castrol EDGE 5W-30 A3/B4SAE 5W-30Castrol Limited
Castrol EDGE 5W-40 A3/B4SAE 5W-40Castrol Limited
Castrol Edge Professional A3SAE 5W-40Castrol Limited
Castrol GTX 5W-40 A3/B4SAE 5W-40Castrol Limited
Divinol Syntholight LL 5W40SAE 5W-40Zeller+Gmelin GmbH&Co.KG
ELF EVOLUTION 900 FTSAE 0W-40TotalEnergies Lubrifiants
Eurol SynduraSAE 5W-40Eurol
Kixx G1A3/B4SAE 5W-40GS Caltex
LIQUI MOLY Leichtlauf High TechSAE 5W-40LIQUI MOLY GmbH
LIQUI MOLY Pro-Engine M900SAE 5W-40LIQUI MOLY GmbH
MINI Original Engine Oil LL01SAE 5W-30Shell International Petroleum Co.Ltd.
MOTOREX XPERIENCE FS-X SAE 0W/40SAE 0W-40MOTOREX AG
OPTIMA MAGNUMSAE 5W-30Modrica Oil Refinery
Pennzoil Platinum EuroSAE 5W-30Shell International Petroleum Co.Ltd.
Pennzoil Platinum EuroSAE 5W-40Shell International Petroleum Co.Ltd.
QUARTZ 9000SAE 5W-40TotalEnergies Lubrifiants
Quaker State Euro Full SyntheticSAE 5W-40Shell International Petroleum Co.Ltd.
Quaker State Ultimate Durability EuropeanSAE 5W-40Shell International Petroleum Co.Ltd.
Quartz 9000 EnergySAE 0W-40TotalEnergies Lubrifiants
Quartz 9000 EnergySAE 5W-40TotalEnergies Lubrifiants
Ravenol HCLSAE 5W-30Ravensberger Schmierstoffvertrieb GmbH
RAVENOL HSTSAE 5W-40Ravensberger Schmierstoffvertrieb GmbH
RAVENOL RSPSAE 5W-30Ravensberger Schmierstoffvertrieb GmbH
RAVENOL VSTSAE 5W-40Ravensberger Schmierstoffvertrieb GmbH
ROLF PROFESSIONAL SAE 0W-30 ACEA A3/B4SAE 0W-30ROLF Lubricants GmbH
ROLF PROFESSIONAL SAE 5W-40, ACEA A3/B4, API SPSAE 5W-40ROLF Lubricants GmbH
ROLF ULTRA SAE 5W-40 ACEA A3/B4 API SPSAE 5W-40ROLF Lubricants GmbH
ROLF Ultra S9 SAE 0W-30 ACEA A3/B4 API SLSAE 0W-30ROLF Lubricants GmbH
ROWE HIGHTEC SYNT RS HC-BSAE 5W-30ROWE MINERALÖLWERK GMBH
ROWE HIGHTEC SYNT RS HC-DSAE 5W-40ROWE MINERALÖLWERK GMBH
SPECIFIC LL-01SAE 0W-30MOTUL
SRS ViVA 1 topsynth-plusSAE 5W-40SRS Schmierstoff Vertrieb GmbH
Shell Fully Synthetic Motor OilSAE 5W-40Shell International Petroleum Co.Ltd.
Shell Fully Synthetic Motor OilSAE 5W-30Shell International Petroleum Co.Ltd.
Shell Helix UltraSAE 5W-30Shell International Petroleum Co.Ltd.
Shell Helix UltraSAE 5W-40Shell International Petroleum Co.Ltd.
Shell Helix Ultra Professional ABBSAE 5W-30Shell International Petroleum Co.Ltd.
Shell Helix Ultra Professional ABBSAE 5W-40Shell International Petroleum Co.Ltd.
Shell Helix Ultra XSAE 5W-30Shell International Petroleum Co.Ltd.
Shell Helix Ultra lSAE 5W-30Shell International Petroleum Co.Ltd.
Shell Helix Ultra lSAE 5W-40Shell International Petroleum Co.Ltd.
TITAN SUPERSYN LONGLIFESAE 0W-40FUCHS PETROLUB SE
TONGYISAE 5W-40Tongyi Petroleum Chemical Co.,Ltd.
Westfalen MegatronSAE 5W-40Westfalen AG
Megol Motorenoel High ConditionSAE 5W-40Meguin GmbH & Co. KG
[th]
Trade name​
[/th][th]
Viscosity​
[/th][th]
Producer​
[/th]​
Sponsored links
Just buy this and use FCP Euros lifetime replacement warranty. After the initial oil change kit it only costs like $20ish per oil change. Thats the cost of shipping it back via USPS and getting a full refund in store credit. Plus they provide the 2 green o-rings that don’t come in the box of the filter. I pay like $20 to ship it back and I get full in store credit. There’s no way you are getting 7 liters of Liqui Moly, a Mann Oil Filter, and those 2 green o-rings for $20 anywhere else. Better than any deal you’ll get at Walmart. And it’s LL-01 approved. Do yourself a favor and get on the train
Oil threads can be controversial...I use RedLine 10-40, in my 2004, 3.0L, M54 engine about 68K miles.
https://www.redlineoil.com/10w40-motor-oil
I heard a guy on the radio (who knows if he actually knew anything...but he sounded like he did!). Anyway he said the "full synthetic" is a marketing thing and that the term was approved as such and that only RedLine and Amsoil are truly full synthetic. Who knows?
CoPilot response:
the term “full synthetic” is true, but it doesn’t mean what most people think it means. In the oil industry, “synthetic” doesn’t necessarily mean “made entirely in a lab.” It means the base oil has been chemically altered to achieve uniform, high‑performance molecular structures
What “synthetic” actually means​
Modern motor oils consist of base oils + additive packages. Base oils fall into API Groups I–V:
  • Group I & II: Conventional mineral oils
  • Group III: Hydrocracked mineral oils (heavily processed)
  • Group IV: PAO (true lab‑synthesized hydrocarbons)
  • Group V: Esters and other specialty synthetics
Under industry rules, Groups III, IV, and V are all legally considered “synthetic.”
Group III “synthetic” (most oils on shelves today)
  • Starts as crude oil
  • Undergoes intense hydrocracking, hydroisomerization, and purification
  • Result: molecules become highly uniform and stable
  • Legally allowed to be labeled full synthetic
  • Examples: Most Mobil 1, Castrol Edge, Pennzoil Platinum, Valvoline Full Synthetic
FWIW, I've only ever bought the cheapest oil that matches BMW's specs and happily followed their 18k etc service intervals. Never had an oil related problem with my 320d getting to 276k miles before the rust took it. Didn't drink any oil. Still had its original turbo.
