Soft-top catches when opening
theosinc930
Hi, my soft top has started to catch on something when opening. You can hear the little motor struggling, and then there's this awful clunk and it opens all the way.
I filmed the problem here:
Does anyone know what this could be?
Thank you.
Thank you. geometry dash 3d
I’m pretty sure I read that it happens when the lining sags over time and starts catching on something. Mine does it too, just not as badly. If you stop halfway, smooth out the fabric on both sides right before it catches, and then continue, you should notice an improvement.
Solved it. The rear window was catching on this trim piece. I sprayed the window seal and the rubber with some silicone spray and it's fine now
Reactions: RMB
