Oil leak
4play
 UK
Found an oil leak, no surprise there, from what appears to be the gearbox drain plug, no leaks I can see anywhere else and the only oil is down wind.
I've ordered a couple of plugs and 2ltr of correct spec oil so hopefully I can sort it when the postman gets here.
I’ve never seen a drain/fill plug leak
You sure it’s not coming from up above? Output seal or similar?
