OBD Scanner Recommendations
Osprey6010
 Birmingham - England
Anyone got any recommendations on an OBD scanner for the 2.0i? Not looking for anything stupidly expensive.
INPA or ISTA is the best bet if you have a windows laptop.
£20 on eBay, and full dealer level diagnostics
Or, if you want something to easily carry in the car, then Creator310 or 410, or Autophix 5900 or 7910 will suit your needs.
All do the same job but I believe the Creator requires you to individually select and scan each module, whereas Autophix has the added facility to do a full system scan. The 7910 is more expensive but does a few extra functions. If you are only looking at a basic level then the 5900 will suffice.
These are both code readers.
If you want to do coding yourself then the aforementioned INPA, WinKFP, NCS Expert, Tool32 suite for a laptop, or a Scanner 1.4 for a laptop.
