I did a quick search for this, but couldn't find any hits, so apologies if I'm re-posting known information. I recently picked up a BMW Scanner 1.4 from eBay [1], and the good news is that it definitely works. Installing the drivers on Win10 is trivial, and it reads codes and chassis information as expected.
However - be aware that the supplied cable isn't standard - certainly ground has no continuity end to end - I stopped checking here, but I suspect that the +5V supply is also open. I found out when I hooked up the scanner on the bench using another USB-A cable that I just had next to me at the time. This was a standard cable, and immediately, the laptop reported an excess power draw on the USB port. What's happening is that the unit is designed to draw power from the car (which it does) but there's nothing in the circuit to stop it trying to draw power from USB if it's available. This also means that when the unit is plugged into the car and laptop with a standard cable, it electrically connects your laptop to the car - which will almost certainly not end well.
This is a shame as the supplied cable is short and a bit wobbly - I'm going to dive into the circuit to disconnect the 5V rails from the USB socket so I can use any USB-A cable. If I remember I'll take photos and post it up here.
[1] https://www.ebay.co.uk/itm/154021453500
