Hello,
I am just about at my wits' end on this one. Have for a while had as the subject describes, but recently got 29e0/29e1 codes which led me to finally try to diagnose the issue. LTFTs were pegged at 30% and obviously fuel economy was... bad. Initially suspected vacuum leak, so I smoke tested the system and found a tiny leak at the charge pipe, which I then replaced with VRSF charge pipe. Subsequent smoke test revealed no more leaks.
Then replaced the (already fairly new, less than 2K miles) coils and plugs. Symptoms persisted. Bit the bullet and did a new set of index-12 Vitesco injectors and had it walnut blasted at the same time. Fuel economy mostly back to normal now, but the jerkiness/bucking and rough/hunting idle at low RPM persists..
Everything done so far in a list:
1. Smoke test, fixed small leak, smoke test again,
2. New coils and plugs,
3. New injectors,
4. Walnut blast,
5. Reset all adaptations,
6. Checked O2 sensors,
7. Checked HPFP pressure under load,
8. AFRs match now and LTFTs around 5% after injectors.
Tried turning A/C off completely in case it was the compressor drawing a bunch of current, but no change.
Am at a loss now.
Anyone have an idea where I could look next? Have thrown a fair bit of money at the problem, so trying to be as methodical about this as I can. At this moment, there are no codes thrown.
Appreciate any help anyone can provide.
3. New injectors,
4. Walnut blast,
Am at a loss now.
