FOR SALE Various items nearly 200 items
For Sale
Morning, have you got a brake master cylinder for a M car?
Hi.
I have a break master cylinder I'm not aware of any differences I'm sure somebody else can enlighten if there is any differentiences.
If there are differences between a master cylinder for an m car compared to any other Z4 then unfortunately I don't have one.
Hi.
They are different. I put the realoem details on his wanted post.
For my M I need a drivers side bonnet catch, mines not locking. A drivers side cup holder, mine won't grip a cup. Also a set of front wheel inner arches with the piece that goes belwo the air vent. Any of this in your pile?
Hi. Thanks for you message.
I have a twin latch with cable from a standard LCI.
I have a driver's side cup holder, but I'm still yet to repair it.
I've never had an M so I don't have inner arches with air vents.
Yes, I do apologise, I thought my post was quite clear. I have only the one and a member from north Shropshire has seat issues. I went can resolve his issue 1st without needing this part then it will be available to you.
I have 1 part and 2 people interested. Once the 1st person has been sorted it'll move on to the 2nd, which is yourself.
Hello Ben ,
I have got the car back on the road and have just returned from a NC500 trip in it and for some reason the seat no longer seems to be an issue . I have no reason as to why it just seems better than it was . I therefore will not be requiring the seat base and springs but would like to thank you for keeping them for me I really appreciate it and hopefully
ZeD_4
will still be interested .
Thanks again
Tony.
Hello,
Bought a set of seats from another forum member and knew it was missing the passenger seat occupancy sensor cable (so do you have one of those please), but annoyingly the seats are also missing the yellow connector block thing (honestly, how has that been separated / lost!?). I'd then have to sell my old seats without them, so need a replacement pair please. I gave up trying to find the part number for this on Real OEM (that's assuming it's still even available). Picture below of what I'm after please.
Hello,
Hello.
Standard or msport seats?
Are they going in a prefacelift or facelift car? And what did they come out of?
Depending we might be able to use your seats as donors.
I have the connector block, I generally keep them attached to the wires that come from the seat belt latch as both wires with the pins on the end are both black and I don't know if it makes a difference which way round they go.
Send pictures of what you have please.
Hello.
Thanks for replying, I'll take some pictures tomorrow and direct message you rather than spamming this thread with them! My car is a 2003 with standard red leather, electric, but NOT heated seats.
The new seats with the missing yellow block I plan to install, are also from a pre facelift car (or so I've been told!). These are also standard red leather seats but are both electric and heated (and in better shape than my own seats). The passenger is good on mine but the drivers is tired, with the foam padding past it's best underneath on the outer (door side) of the seat.
Post pictures in this thread as it's not possible in direct messages.
I have a complete seatbelt clasp and wiring.
To add heated seats you'll also need the buttons just above the ashtray. Being an 03, you should already have the loom.
OK didn't realise you can't do pictures in messages!
Pictures below of the drivers seat. There are 6x cables (circled in red) and the missing yellow bit should be where the blue circle is I think.
Second photo shows an additional 7th cable coming out the back of the upper part of the seat.
I've got the buttons part to fit above the ashtray.
Looks like you need the whole seatbelt clasp and occupancy sensor.
The black wire coming out the back will be for heating and will connect to the heating loom for the base. Picture 2 is the heating loom.
Remind me of your location? I have the parts to make good. Easier to see in person though.
