Who did this…
bigwinn
Elite
 Lincoln UK
Seriously own up
Had a car over for roof issues. I knew this was the issue from looking at it previously: had to change all 4 roof hydraulic lines… because someone previously decided to extend them and used brake line fittings to do so
Unbelievable
At one point prior to fixing the lines I connected the roof motor and it was like the Trevi fountain in the boot
And did you manage to give it some? ;)
No idea what you are talking about. All I noticed was the lack of weeds or moss between your drive pavers. How do you keep it so weed-free, cos mine is shite no matter what I do. :)
Bleach is your friend Andrew. 👍
Anyway I'm not responsible for that mess, as like mmm-five I've never had a folding roof.
Possibly yanked through in the North West and kinked the pipes so had a repair added?
I’ve had two of those particular relocations with kinked pipes. But never had a repair like that.
I guess if you do the job in 45 minutes you don’t have time to check the orientation of the pipes.
Allegedly
had to change all 4 roof hydraulic lines… because someone previously decided to extend them and used brake line fittings to do so. At one point prior to fixing the lines I connected the roof motor and https://kai-health.com/ it was like the Trevi fountain in the boot https://kobilabs.com/signs-and-stripes/
That is absolutely mental. It's a classic example of why you shouldn't use components designed for different pressure systems on these Z4 roofs. Glad you managed to get it sorted properly, as those leaks can cause a right mess with the rest of the boot electronics if left unchecked.
