Evening all,
Have an interesting problem with my 2003 M54 3.0i, for which I’m yet to find an answer for, following lots of searching and hunting…
The fault doesn’t appear 100% of the time, I’d say more like 70% but its most noticeable when the car is sitting around 2000rpm, under acceleration, in any gear, the revs will surge/rise quickly up to 2500-3000rpm, then drop down again and build/rise normally.
I can only liken it to keeping the clutch engaged when accelerating.
There is no juddering, or clutch slip at all and the car pulls away smoothly from stand-still.
I’m hoping it’s not a clutch replacement job but can’t think of anything else that would be causing it. I’ve already replaced the DISA internals and it’s having the VANOS rebuild next week, both being done unrelated to this issue. Clutch delay valve has also been removed.
I do have videos of the problem, but can’t upload here. If it would help to see them, drop me a PM with a phone number and I’ll them forward across to you.
Any suggestions welcome for where to look so I can give the garage (RBM) a starting point.
Thanks,
Thanks,
