But presumably that's because the Z3s didn't have run-flats. E46s didn't either so they came with a spacesaver, but E9*s had run-flats so like Z4s they also came with nothing.Makes me laugh how BMW provided a space saver under the boot floor on all Z3's but none of the Z4's - that said I think that's the way most manufacturers have gone now.
You’ve said it now!Don't think ive carried a spare wheel for over 10 years now. Havent yet encountered anything that simply reinflating the tyre didn't fix enough to get me home.
Been much debated and depends on how far you venture from home and subsequent consequences..Don't think ive carried a spare wheel for over 10 years now. Havent yet encountered anything that simply reinflating the tyre didn't fix enough to get me home.
I would thinkBeen much debated and depends on how far you venture from home and subsequent consequences..
FWIW I've now seen about 12 punctures between me and my Zed friends on trips plus our own fleet..
Out of the 12..only two were fixable with gunk/rats tails..
Maybe its a function of Scottish roads!
Just been out for a drive to Teignmouth, 2 massive pot holes almost next to each other stretching across the carriageway on a series of bends. Saw the first one, swerved to the right to avoid and then to the left clipping the one on the right by the white line. Absolute disgrace.![]()
E46 17" ones are available from the 330i and 330d, but E9*s didn't have one as they were all supplied with run-flats and no back-up solution. From what I can make out E46 M3s just came with a "Mobility Kit" like Z4Ms, which means an aerosol of sealant and a compressor!I’ll look for an E46/90 in 17 or 18” if they are available.![]()
I’ve a Z4M…there was a spare available for the E9X cars albeit, they never came with one. Worst case scenario, if I had a puncture on the front, I’d put a rear wheel on the front and the space saver on the rear… I am sure they fit.E46 17" ones are available from the 330i and 330d, but E9*s didn't have one as they were all supplied with run-flats and no back-up solution. From what I can make out E46 M3s just came with a "Mobility Kit" like Z4Ms, which means an aerosol of sealant and a compressor!
Sorry I can't remember which Z4 you have, but a 17 is big enough to clear 3.0Si front brakes. If you have an M it might work on the back, but that's not so good for a puncture on the front.
Sorry I maybe wasn’t clear, as I understand they never did come with one, but BMW and some other outlets would sell one as an emergency wheel I believe, in a kit. It just lay in the boot which isn’t the worst of things if you travel a lot in the car.Oh right, I didn't know you could get a space saver for E9*s. The well below the boot floor certainly isn't big enough for one!
A 17" space saver would probably fit the rear of an M, but I'm not sure about a 224 rear on the front as the offsets are quite different. It might be worth trying that out before you commit.
