Good morning for the Midwestern US. The weather this week is unseasonably warm so I decided to pull the Z4 out of the garage from her winter nap and driver her to work. When I got the car out of the garage, there was a fresh transmission fluid stain. Prior to garaging her, I had the mechatronics gasket and the wiring harness seal replaced. The trans pan and filter had been done within the last year. The car was not leaking after bringing it back from the shop but now, a month later the leak has returned. I've already contacted the shop and I'm waiting to hear back from them. Other than the filter housing, pan gasket, harness seal and mechatronics cover seal, is there anyplace else the DCT leaks from. The car is a 2012 sDrive 35IS.
Subsequently, on the way to work this morning, the check engine light came on for fault code 29F4: Catalytic-converter conversion. One of the possible causes is an exhaust leak on bank 1. What is the liklihood that this is related to the prior transmission repair? If I remember correctly, to drop the transmission, they had to remove the exhaust but I'd imagine that they would only drop the exhaust from the end of the down tubes back. Any help is appreciated.
In unrelated news, when I checked the engine codes, I also had a code for DWA [DWA_63] | 9D12: Internal battery discharged. Does anyone know where this battery is? Is it a replacable battery or do I have to replace the entire module?
Thanks everyone.
Thanks everyone.
