Varixto
Does anyone know of a good convertible roof specialists not a million miles away from Suffolk?
My car has an annoying clicketty, creaky noise, which is driving me insane. It happens when I go over irregularities in the road surface and it's specially noisy if the chasis/car "bounces" (ie: goes up and down). For example, if I go up then suddenly down on a ramp.
It only happens with the roof up. With the roof down, it's fine.
I can hear it (and feel it with my hand) right behind my right ear (ie: right hand side). Place my hand in that area, I can feel the clicks, like metal against metal).
I think I have located the source of the noise to this part:
This is the control rod, according to a manual I have found online (it's for the 35iS but as far as I know the roof is the same):
The manual asks to check that the gap between the rear retaining hook (1) and roller (2) using a drill (3) is 3+-0,5 mm. Then check visually that the gap between the front retaining hook (4) and the roller (5) is 0.5 mm. If these measurements do not match, the manual recommends to replace the control rod (ie: first picture).
Could this be the culprit? (ie: a gap between the hook (4) and the roller (5), causing the creaking sound I hear behind my right ear when the car bounces a bit over irregular surfaces). It matches the area I can hear/feel the noise coming from...but the sound itself is hard to describe.
Here's a sound clip of the noise I recorded with my phone: https://drive.google.com/file/d/1G2LYBiXubX_-MyEaYizL7uGKUKqgWFj9/view?usp=sharing
Something misaligned? I don't think it's left/right; I am quite sure it's up/down... or the control rod? I am totally lost here...
I remember coming across someone in another forum with a similar problem mentioning a "roller" problem in his roof (also an e89, I think) and by adjusting it, the problem was fixed. I remember he posted a link to a Youtube video with a similar (but more extreme) noise.
However, from what I have read in the above mentioned manual, it seems that adjusting the control rod only helps if the latch doesn't fit properly in the slot at the lower back part of the roof...
Furthermore, it seems to me that now, with the sunny weather, it's got worse and whilst during the cold months it sounded a bit more clickety, now it sounds more creaky.
The car is lovely and I am very happy with it but this noise is driving me nuts and spoiling a bit my enjoyment of it.
Any help and/or advice will be much appreciated.
