DISA repair kit experience and motor fix
Natto
Hi All,
I recently had complete large disa valve shaft failure on my e86 3.0si and just wanted to share my experience.
Having turned my nose up a bit at the ~£300 cost to replace with OEM (as far as I've read, the only thing worth replacing it with), I decided to try out a rebuild kit. Specifically the one from klifex in Ukraine: https://klifex.com/remkomplekt-disa...79114-11617560537-11617522929-bolshaya-lopast
(I am not associated with them in any way)
Really nice quality kit, full aluminium construction with a central solid steel shaft and a more closely fitting oil seal to hopefully prevent ingress in future. Install of this went well and I test assembled the new valve. (plenty of guides for this elsewhere on n52 related forums)
Testing this with ISTA revealed that the valve was only moving slightly in each direction. All research online suggested to me that this meant the motor was kaput. The large amount of oil in the disa casing did support this theory.
So, I thought that it was worth giving anything a try to fix this disa valve before giving in and buying a new or lightly used unit. I sprayed the motor liberally with GT86, which says it can be used for water displacement in electronics. Then I put the motor itself in a vice and ran it backwards and forwards for a while using a benchtop power supply, then reassembled in the disa valve.
It then worked perfectly, actuating open and closed quickly and in one smooth movement. Hope this can help anyone in the same situation! I figure that since a failure of this unit won't leave you stranded, it's worth having a tinker and try fixing it before resorting to replacement.
- Nathan
Thanks for sharing, good to know that the Klifex kit fits without any issues. At what mileage did the DISA fail? With the shaft being plastic it’s probably more age related so definitely something worth putting on the preventative maintenance list (in my case).
My first DISA I think was failed when I bought the car at 123,000 miles. Based on the paperwork I don't think this had ever been changed. I replaced this with a used unit (unknown mileage but working), and then recently decided to investigate a bit of a low power feeling at low RPM and found this second DISA completely failed and full of oil.
Good catch then. I know that in the older M54 engines the DISA valves came apart and parts of them ended up destroying more than 1 engine.
  • Wow
Reactions: RMB
Bookmarked, thanks. Hope I don’t need the kit anytime soon though. Good work.
I took my Disa off my 3.0i today to do the upgrade with the X8R kit I've had for a while.
I refreshed myself with a few YouTube videos, which suggested that if you close the Disa flap and cover the little hole, it should only open part way and then stop, and then open fully when I release my finger off the hole, and if it doesn't stop and it continues to open fully, then the diaphragm is shot.
When I tested mine, the flap opened fully with the hole covered, so I've ordered a replacement Disa off eBay and will apply the X8R upgrade to the new Disa.
Car runs and drives absolutely fine with no obvious audible erroneous noises. Maybe I've caught this just in time?
The vacuum failure only stops it functioning correctly. It's the flap and hinge pins that cause the big problems.
