Odd, as mine does this too. Also retrofitted to a 2.2. It's really only noticeable with both sponges removed, and sounds like a vibration/rattle at the start of the rev range. I've checked everything and can only assume that it is the diaphragm vibrating. I can replicate the noise if I tap the diaphragm area under the bonnet, it almost sounds like something inside it is loose. If you do find out what it is, I'd be interested too. Currently using just one sponge, so I can't hear it - 2 out was a bit loud anyway! Also, I've always wondered whether the diaphragms could fail with time and allow unmetered air into the engine, causing running issues?
