Something nice n geeky for those whose previous technical forays were agonising over which colour to paint their alloys…
Here is the CIC computer which powers the idrive screen and system.
Used for the E89 for it whole run and first released in 2008..its a product of the very early 21st century..
Still useful as its plugged into many sub systems on the E89 and with a MMI box does a great CarPlay rendition.
The map data and the cd track info and possibly some stored audio resides on a 80gb ruggedised hard drive similar to an old laptop drive.
It’s held in a cradle and can be easier swapped out.
There are a number of failure modes on these units, one is the failure of this drive.
A geeky dodge is to clone the contents of the drive before it fails and transfer it to a solid state drive..
Apart from better reliability the SSD has much much faster I/O…over 10 times faster at 50m/bytes per sec
So…your menus won’t operate faster but any map function will be a lot quicker…
There's a chicken and egg issue..you have to copy the image of the hard drive BEFORE it fails..then its too late.
The drive was formatted and used in a Unix system (QNX) that idrive on E89/90 uses.
So any normal PC file utilility will fail.
As you can see there's not that much actually stored on the drive.
Pointless storing audio as its crap quality!
You need a whole image file manager and an adapter cable to be able to read the old hard drive and then write that to a USB stick..then read the USB stick to write to the new SSD.
Fof those who asked the old hard drive is held to its carrier with just 4 small screws..remove them and fit the now copied SSD and you are good to go!
