Well I can put the indicators to one side for you, however, swapping from halogen to xenon isn't straightforward. You need to change the light control module (LCM) which will need coding to match the instrument cluster and I Believe there are wiring changes too.That sure is Liams Racecar build.
All mods have been declared to my insurance company.
I would definitely be interested in some clear side repeaters given ill be changing the front headlights to clear, as the halogens are pretty sub par so will need to be upgrading to xenons when a good set comes up!
I also forgot to mention that this Z4 will be joining its bigger brother the N52 Z4 Coupé which is owned and raced by my dad.
That sounds good with the side clear lights! Instead of swapping the whole headlight unit could i remove the headlight lense and put clear lenses on? Im not sure if this will help with changing the orange indicators or not though...Well I can put the indicators to one side for you, however, swapping from halogen to xenon isn't straightforward. You need to change the light control module (LCM) which will need coding to match the instrument cluster and I Believe there are wiring changes too.
@bigwinn may be able to advise on that I think.
Just in case you're misunderstanding; you can get halogen and xenon headlights in both orange and clear indicator types.
Thanks for the welcomeGreat to see you on here Max . Your dads build thread is going to take some beating![]()
Something in the back of my mind says someone did it, but I’m not entirely sure how?That sounds good with the side clear lights! Instead of swapping the whole headlight unit could i remove the headlight lense and put clear lenses on? Im not sure if this will help with changing the orange indicators or not though...
Like a charm! Peeled back the boot carpet and the connectors were right there in the centre console recess. Bit of tape and a cable tie to secure. Took all of 15 minutes.@Max Crilly - did the bluemusic dongle thingummy work?
