2011 Z4 sDrive 35is ~105K miles.
Problem: When opening the roof, everything works fine until the final stage (back glass folded on top of roof, clamshell open). The pump sounds like it's attempting to lift the assembly, but can't. I can even hear the seal along the top of the windscreen separate, so it's TRYING to move. With no assistance it will eventually error and blink the button LED red. However, if I assist and lift the roof assembly a little, then it will complete. Closing the top is fine, everything works as normal.
Things I've checked:
- The hydraulic fluid level is at the MAX line, and it's never been filled so I think that eliminates any chance of leaks.
- Sensors/switches seem to be working. I don't get any codes when checking with Rheingold (ISTA/D), just an error on the car screen saying "Hardtop" or something like that. Also, a few years ago I replaced the section that commonly breaks on all the wires in the roof. I had 2-3 that were broken/ready to break so I just did them all.
My guesses:
Gas struts: I've never replaced the gas struts for the roof, but every thread I've read doesn't indicate that these assist with opening/lifting the top, only with dampening the close motion.
Internally leaking cylinders: I'm skeptical about this because closing the roof works fine. I suppose the seal could be failing in one direction and not the other but it seems unlikely.
Dying pump: the pump sounds normal I guess, but I'm not really sure how I'd know.
I can get a video of the problem happening if it would be helpful. I searched and read through a bunch of threads but didn't find any that matched what I was seeing. I've dealt errors regarding broken wires, those trigger pretty obvious codes. I'm not sure why no codes are showing up for this.
My guesses:
