Hey guys
Had my project 2003 e85 for 6 months now and have been working through some issues.
The one I'd like to focus on is the roof.
When I bought the car, the roof didn't work, suspected roof motor which the seller supplied with the car.
I took the roof off, relocated the new roof motor to the boot (trunk) and all worked well on assembly.
I had a seperate issue with some warning lights which turned out to be a damp yaw sensor under the drivers seat (rhd).
I disconnected the battery (for 2 weeks) while I waited for an Ebay yaw sensor, fitted it and the warning lights disappeared.
It was at this point that my roof issues began.
Symptoms were no movement, no motor noises or lights at all when pressing the roof switches.
I assumed no power so checked the 3 fuses and all were good.
The car hadn't moved from my garage.
Power was getting to the roof module but not past it to the switches.
I got an Ebay roof module and put it in. It didn't work at 1st but then started working a day later.....until it stopped working.
The car still hadn't moved from my garage.
No roof faults were shown on the code reader.
I decided to take it in to bmw for a more thorough diagnostic.
In usual bmw fashion they wanted to fit new parts to eliminate possible issues but couldn't guarantee anything.
The technician wanted to replace the roof module but said if it didn't fix it, it could be a broken cable that could take hours to find at £150 an hour.
I got the car back home to investigate myself.
I took the roof off again yesterday and flipped it over onto a panel stand to test all the cables with a multimeter. No breaks or kinks. The only ones I didn't test in the roof were the 4 thin ones that go to the sensor on the nearside (uk) roof ram. They were in good condition though.
I hooked up a 12v supply to both the main roof motor and the front latching mechanism motor. Both worked as they should.
I tested the length of cable (2 wires) that go from near the roof module to the relocated roof motor. Both were good.
I've now refitted the roof, buttoned everything up (including parcel shelf, microswitch and red manual realease tab) but I'm no further forward....except I now have 3 roof modules
The original one that was working fine until the battery was disconnected, the 1st replacement that worked for a short while till it didn't...and the 3rd one that has made no difference at all.
I've looked through loads of posts regarding roof issues to try and shed some light on my issue.
Technician at bmw said that the roof module needs to be paired but lots of members here have said that it doesn't.
My issue has remained unaltered. No roof operation, no lights when pressing the roof switches.
Both motors operate when hooked up to a 12v supply, no breaks found in roof wiring.
Apart from the trip to bmw, the car hasn't moved from its spot in my garage. The battery is fully charged (well 90%).
Apologies for the long post but wanted to provide as much info as possible.
No doubt many of you will be rolling your eyes and saying "not another bloody roof"
Any advice or suggestions would be greatly appreciated.
Many thanks
Steve
Many thanks
Steve
