What an honor.I was waiting for your reply.
Best info ever! I'll head over to you and we'll fix all issues together. Currently it's rainy and "fresh" in Bavaria.warm weather here "summer over 40 C".
The JunctionBox is responsible for opening the lid! It has to be selected, than try to unlock the trunk lid.The trunk is open "lid is locked".
I turn on the ignition and initiate closing, the button click but no action whatsoever.
In short:Is that mean a problem with fuses?
CTM at first checks all sensor as well as the actor values before starting to run the hydraulic pump. If any signal is wrong or missing, it won't start.when I press the button "closing or opening" it shows change in position. All other live stream no change.
This doesn't help in any way. TBH, forget it.
In total there are three 180° bows in the hydraulic harness:
Wires up to now will only break in the upper as well as in the inner bow.
- the lower, visible one
- the upper, invisible one in the rear roof shell
- the inner one, on the opposite side of the lower bow, but currently stretched to 0° (zero degree) while you have a look at it
Pretty sure a broken hydraulic hose.Now I can see oil dripping from the right piston but not sure if it is the connection, hose or the piston itself.
TBH, that is technical n.nsense.What come and go into my mind is, can I disable hydraulic power and make it manually operated.
OMG, these pictures all look like a nightmare. This is exactly how you shouldn't work on these special cars!
All the cables there were violently ripped down! That's how you destroy the entire structure. Not good, badest idea at all.
This looks like a total loss.
Great, this is my plan but i will save some money till next summer. since then i will play with these wires and hoses.A hydraulic hose is broken in the upper bend (not on the hydraulic ram), so the entire hydraulic wiring harness needs to be replaced as single hoses are taped-in and can't be replaced individually (your video, 0:27 min). Keep in mind, that all hydraulic hoses are already pre-broken due to it's mechanical overloading.
54377311084 Set, hydraulic line with wiring harness
Getting this part replaced, all i.e. sensor wiring is integrated and will be renewed as well.
It's a very complex operation that takes 1 day (or another for newbies)!
HoweTo: Guide for replacing old hydraulic lines
Hint:
Be very carefull with the two brass "screws" on top of the hydraulic ram. These are valves and not just screws and may only be turned a maximum of 2 turns. If overturned, jou'll destroy the complete hydraulic pump.
Well, there is a difference between technical issues like broken wires, defective sensors and on the other hand, a logically issue like a not perfectly locked roof.What I cannot understand why it is showing "roof system" without any fault code!!!
To be honest, IMHO absolutely nonsense I'm warning against over and over again.The white paints on the hinges is Never-Seez Compound, I followed this video:
I will clean them with WD40To be honest, IMHO absolutely nonsense I'm warning against over and over again.
You will catch dust, but never get into the hinges itself, where always a soft metal bushing is integrated.
Even WD40 isn't a recommendation. It's a more or less agressive cleaning spray. Just take a tissue and remove the grease.I will clean them with WD40
I remember I red about the bushing and no need for greasing but that after I did greasing....
You don't have to push anything back. The roof is able to restart/continue from every position, if all sensor values are ok, physically and logically.Is it because I lift the shells from the trunk to the top position?
Shall I return them to where they were?
I don't have INPA but ISTA and I can take screen shot of each sensor status.You don't have to push anything back. The roof is able to restart/continue from every position, if all sensor values are ok, physically and logically.
As I don't know the status of each sensor, i currently can't answer your question. Each sensor should deliver a clear status on INPA. If any fails, INPA shows graphically a black bullet on the right column of the views.
The best would be to present the different INPA views regarding the sensors. In addition, the pages of the prerequisites.
Hopefully not in Arabian.I don't have INPA but ISTA and I can take screen shot of each sensor status.
Here, this is the first time I found fault code for CTM, maybe after I connect the connector near top shellThe best would be to present the different INPA views regarding the sensors. In addition, the pages of the prerequisites.
Here we go:Here, this is the first time I found fault code for CTM, maybe after I connect the connector near top shell
No description but here is the details:
and here is the state reading "sorry so many pages"
when ISTA read state some of them alternate between "not operated" and "not available" not sure if that means anything or just the way ISTA read
OK, I reconnect the connector and replace 4 wires.
BUT still
This video shows what happens when I press the button
This video shows read state
It is not latching thats why it is stuck
I think I will pack the shells into the trunk and see what will happen
This is configuration of ISTA.Dont' understand the 2nd video: why are there so many signals missing?
