Rear brake pads. Squealing.
bluespit
Senior member
 Near Chester
My rear pads squeal badly at very low speeds. I suspect they need replacing with better branded examples. I’m fine doing this with one caveat- what to do about the electronic parking brake.
Leave it off seems obvious but I’ve read about them ‘self activating, with dire consequences
Can’t find a definitive guide so advice welcomed.
Gary
Definitely Definitely DO NOT have the EFB on at ANY TIME during the pad replacement process…it will be a bad hair day..
You’ll need a pp3 battery and some jump wires or a coding tool to put the efb into service mode
EFB? =Parking brake?
Release the parking brake as normal and unplug at the motor. Then just remove the motor.
Wind the the piston in with Allen key to get the pads wide enough apart to pass disc wear lip.
one side done - turns out my cheapo code reader thing will rewind the parking brake!
other side tomorrow when I've turned the car round in the garage
I used Foxwell reader to wind them out, but not far enough to get over wear lip so still had to manually wind them out.
