September 2025 — Deep Service + Tires
Did a big mechanical refresh this month: stopped the leaks, fixed the clunk, replaced missing plastics, and finally added new rubber.
Total Service: $9,491.77
Tires: $822.66 (Tire Rack, shipped to installer)
Result: Quiet, tight, no oil smells, and finally tracks straight again.
Findings
• Rear differential bushing torn, causing rear clunk
• Valve cover leaking onto exhaust (N52 classic)
• Eccentric shaft sensor leaking
• LCABs soft and cracking
• Underbody plastics missing or damaged
• Cowl seal cracked
• Weak hood struts, streaky wipers
• Uneven front tire wear, mild misalignment
Fixes
• Replaced rear diff and subframe bushings
• Installed new valve cover, gasket set, and cam adjuster gasket
• Replaced eccentric shaft sensor and seal
• Dropped subframe for oil pan gasket and LCABs
• Replaced all underbody plastics (fender liners, belly panels, engine cover)
• New cowl seal and cover
• Turn signal bulbs, brake fluid flush, transmission + diff service
• Mounted new tires and did a 4-wheel alignment
Tires
Ordered from Tire Rack — Continental ExtremeContact DWS 06 Plus (SL, Ultra-High-Performance All-Season).
• Front: 225/45ZR-17 @ $168.99 × 2 = $337.98
• Rear: 245/40ZR-17 @ $210.99 × 2 = $421.98
Subtotal $759.96 + tax $62.70 = $822.66 delivered
Installed, balanced, and aligned during the same visit.
Cost Breakdown
Job Cost
Diff + subframe bushings $1,670
Valve cover + gaskets $980
Underbody panels $1,742
Cowl seal + cover $603
Eccentric shaft sensor $632
Oil pan gasket + oil service $1,176
LCABs $470
Fluids + brake flush $497
Tire install + alignment $409 (excl. tires)
Notes
The N52 leaks were predictable but satisfying to fix right. Eccentric shaft sensor was oil-soaked, and the old underbody plastics had basically disintegrated. Now the underside looks OEM-clean.
The new Continentals are a big step up in ride and steering feel. With the alignment sorted, the car feels like a proper roadster again.
