Anyone in Hampshire who can help?
I am in search for B-pillar sensor replacement and codding in.
My original sensor is
RealOeam.com shows that i can replace it with any of below part numbers:
65776948087(03/18/2004 — 10/25/2023) , Exchangeable retrospectively
65776928571(11/25/2002 — 07/11/2003) , Exchangeable retrospectively
65776928520(09/02/2002 — 07/01/2002) , Exchangeable retrospectively
65776926784(09/02/2002 — 05/22/2002) , Exchangeable retrospectively
65776926782(09/02/2002 — 04/23/2002) , Exchangeable retrospectively
https://www.realoem.com/bmw/enUS/partsearch?id=BT52-EUR-03-2003-E85-BMW-Z4_30i&mg=&sg=&q=6933985
Fault was present when i bought the car.
Fixed the Occupancy sensor fault with the a adapter with resistor (bought it of ebay)
- this is working now and I can hear the signal going off after reaching certain speed - it is pretending that a passenger is sitting there and when i clip "their" seat belt in the signal is not present any more.
I have read the fault codes:
After reading many posts about the Airbag Light ON issue, my understanding was that the SBSL sensor needs replacing and coding.
Have removed the sensor of the car to check for any water damage but nothing indicated it, not even any small signs of oxidization.
But what i have found was that the carpet underneath passenger seat was soaking wet ( but only bottom part of it- the foam that is underneath- i could not feel any damp on the top.
Checked all seals around the door and have not found any water leak. But found a lot of water present in the area where roof motor is originally placed by design (btw this motor has been relocated already).
I have cleaned the drainage whole and now for few weeks of our rainy weather there is no more water accumulation there.
Long story short- I wanted to ask you guys- do you think that water accumulation could be dripping under the carpet and damaging SBSL sensor on its way?
Is that 987B code saying that it has been replaced by previous owner but not coded with VIN?
- I think I have found the answer to above question- The code of not coded correct VIN would be "93AB Incorrect Chassis number"
@enuff_zed- forum posts show like you have a lot of experience in this matter- would you be able to suggest anything?
65776933985
