Three conflated ideas
Frequent oil changes is always always a great idea..a great oil on extended intervals / lots of stop start is not going over the long term do as well as a fractionally 'lesser' oil much more frequently changed.
If you have inherited a new car /engine then there's the issue of is it really clean inside..in which case running an oil high in detergents for at least one change /short period of time is a great idea.
Modern spec oils by exclusion will never include 50+ weight oils as those specs call for 30w and now some are even 12w 0r 20w.
What modern oils do have are some of the later additives to help cam chain wear and detergents.. avoiding clogging up cats, dpfs etc.
So what you need ideally is an oil that met the original oil spec but exceeds that spec in areas like volatility, shear strength etc..
So currently the oils that have a high ester content are the current kings for an old motor like the S54!
Redline and Fuchs are the two kings of ester based oils.. others market esters but refuse to disclose the actual content.,
There is a very very sad web site Bob the oil guy where people wax lyrical on all these various oils FWIW
