Thanks! So to access you go through to the boot or the wheel well?It’s located behind the luggage compartment wheel arch trim on the left.
In the boot, on the left, behind the carpet. The diversity antenna is part of the HiFi system, it doesn’t have anything to do with the keys.Thanks! So to access you go through to the boot or the wheel well?
I've read the module is also to transmit the signal for the remote central lockingIn the boot, on the left, behind the carpet. The diversity antenna is part of the HiFi system, it doesn’t have anything to do with the keys.
If you have a problem with key fobs I'm not sure this component would be the right place to start investigation.
Incorrect. I located the Diversity Antenna, brought a new one from eBay, swapped out - and Bingo! The remote central locking is now working.In the boot, on the left, behind the carpet. The diversity antenna is part of the HiFi system, it doesn’t have anything to do with the keys.
Incorrect - it's the diversity antenna in the bootThe receiver for the key FOB is inside the rear-view mirror.
What I wrote (cut and paste) is directly out of the BMW E85 service manual.Incorrect - it's the diversity antenna in the boot
I stand corrected, although I am very surprised. Nothing that I could find in NewTIS (functional descriptions, wiring diagrams) supports this.Incorrect. I located the Diversity Antenna, brought a new one from eBay, swapped out - and Bingo! The remote central locking is now working.
