Hi
Following ownership of this wonderful car for the past 3.5 years. The time has come, to offer my Z4 Coupe to a new custodian.
Genuine reason for sale, moving into an Alpine.
2006 - 56 Plate
E86 3.0si Auto - This car is in SE spec, SE's have a higher ride height, and are more softly sprung, this in my opinion offers the sweet spot for comfort on uk roads. and is supportive for making swift B road progress. SE's also benefit from a thinner rim on the steering wheel and is nice to hold.
2 Keys
82k miles
4 Owners
Silver Grey metallic paint
Heated M-Sport seats in Oyster
Non pop-up Nav model. So has a clean looking dash
Piano black trim
Light colour headliner (specific to SE)
BMW & indy specialist service history.
Leather binder with all original books & supporting invoices
Items Installed/Replaced under my ownership
Newly refurbished staggered OEM BMW, MV1 wheels, with correct offset. Fitted August 2025
10mm Spacers fitted
New rear tyres - Goodyear F1 Supersport 255/35 R18 fitted August 2025 - Fronts are also F1 Supersport with good life remaining
Xenon Headlight projectors, Bulbs & lenses, with PPF applied - Phenomenal performance upgrade
Bosch S4 battery
Blue Music Bluetooth adapter that's hidden behind the factory radio, facilitates Bluetooth audio streaming.
Boot hatch Gaz struts
Oil separator valve, with top & bottom associated hoses
Transmission Oil change
Diff Oil change
Rocker cover gasket
Sump gasket
Starter Motor
Waterpump
Front brake calipers PAIR
Front and Rear shocks, springs, top mounts, spring pads, dust seals, ARB droplinks & bolts.
4 Wheel alignment
Front foglights have been removed, split & refurbished with drainage holes drilled, to prevent future fogging.
The car presents very well. It does have some stone chips as to be expected on a car with this mileage.
Note that, the rear parking sensors are inactive.
Private plate is included in the sale.
Vehicle located in Wakefield
Asking £8250
2006 - 56 Plate
2 Keys
82k miles
4 Owners
Piano black trim
10mm Spacers fitted
Bosch S4 battery
Diff Oil change
Rocker cover gasket
Sump gasket
Starter Motor
Waterpump
4 Wheel alignment
Asking £8250
