Guys,
Its been a while since I've last posted and to be honist a while since I drove the Z4.
I've had a leeky boot and flooded battery compartment, not once but twice now.
After I dried it all out the first time, the hydraulic pump and motor were underwater for quite a while and the water was turning that rusty colour.
but after I took it all apart and dried it off, replaced the relays as they were shot. Put it all back together, replaced the hydraulic fluid it all worked like dream. Changed a broken seal in the boot and thorught I'd fixed it.. but this is a Z4 after all.
So no I discovered a battery box full of water again, not as much the second time as I'd been keeping an eye on it. But it still got wet. Why did they not design the hydraulic motor support to be waterproof ?? and not a spunge!! anyway, dried it all off again changed the bloody relays again and it all worked, so I was happy bunny.
I then took all the boot trim out to see if I could find where the water leak is coming from, did remove about 2 pints of water from the sides of the boot though,but no luck in finding where it came in, but the trim is all out still.
So today I thourght as its a nice day, I'll go see if I can put it all back together. Well the boot is all dry but now the roof wont open, even the windows don't go down. I have a smart top fitted so the roof should open from the fob, but this never worked. So I put the key in the ignition and the open roof LED goes red when I press the roof open button and I get a "Roof Movement Impaired "up on the idrive screen.
Does anyone know what that means?
and whats the best/cheapest fault code reader so i can find out what the issue is
Many Thanks
Jon
Many Thanks
Jon
