WARNING:
Wall of text and stream-of-consciousness below. Read at your own risk
My 2016 Z4 headlight beams are very low. Like, maybe a car length or so from the front of the car.
I've determined that I likely have an issue with the level sensors. In doing research, I can't find anything on them in the Service Manual I've been able to download online. Searching keyword "headlight" did not produce anything meaningful on these sensors. Searching "ride level sensor" brought one hit for the bracket fastening torque of 8Nm, but nothing on the sensor itself.
So I then looked for videos or other resources like Youtube, and it's hard to find anyone who is going over the procedures for both front and rear. So I've decided that I'll need to figure a lot of this out on my own. I vaguely know what they look like and about where they are on the vehicle. Can I apply the same procedures as an E85? So far, all pics or videos I've found are closeups which do not give much context like how/where to position myself and reach the components.
RealOEM insinuated that it would be on the driver's side, but I couldn't find anything. I found the rear one on the passenger's side. I then realized that realOEM is likely giving examples from a RHD car, and not LHD
I took off the rear wheel and was able to see the sensor (barely), but I determined that being under the car was the best approach angle for replacement.
37146853753 - Front Sensor
37146784697 - Rear Sensor
I didn't see anything immediately wrong with the rear sensor. I was able to manipulate it though. Almost like its position had changed, and I was able to get it back into place. Moving it to the other resting position didn't fix the issue like I had hoped. It's hard to descripbe how the sensor moved as I still don't exactly know what parts it's connected to and how it gets its input. I have yet to look at the front sensor but I assume it's also on the passenger side. This may be something for tonight.
1. How can I check the sensor voltage being produced by these sensors in real time? I've learned that it should be 0.5-4.5V
2. Can I code the car to ignore the sensor input for the purposes of aiming headlight? I found these two possible code adjustments. Will they possibly help me?
AUTO_LWR_ENABLE nicht_aktiv
DYNAM_LWR_ENABLE nicht-aktiv
3. Do any other systems use data from the level sensors?
4. What happens if I unplug them, will the headlights go to a neutral position?
5. On startup, when the lights move around, am I seeing the full range of motion? If I see them dip after the self-test, is that a clue?
6. Do I need to remove the wheels for sensor replacement & viewing angle or can i entirely find and replace from under the car?
I plan to eventually replace the sensors if they're the issue, but I am wondering how to best troubleshoot. If unplugging them will cause a neutral aim, then that would be sufficient proof that the issue is the sensor and not a need to aim the lights with adjustment screws. One goal is to avoid using the adjustment screws before ruling out any sensor issues.
