DCT Service - When to do it? If at all...
James35i
Hello All,
Coming up to the mythical 100k miles in my 35i, which has recently passed its MOT without a single advisory (happy days).
With this milestone coming up, it's gotten me thinking about things that may need to be done, and one of them is the DCT service. Currently, there isn't a single thing wrong with the shifting; it's fast and tight, which makes me a bit reluctant to spend a good chunk of change on it.
So my question is, people who have had it done, did you do it because you noticed an issue with the gearbox, or did you do it simply because you hit a certain mileage? An indication of the price for the service would also be appreciated.
Thanks all!
60k miles is what the manufacturer of the box recomends (not BMW).. ZF oil and filter kit around £300 plus labour
BY the time you notice the issues a lot of damage has been done
Without hooking up full diagnosticss you've no idea how much work the box has done.
If its a keeper then do it..if you're going to off load then don't bother
Brilliant thank you B21!
It's certainly a keeper, I'm about to spend an arm and a leg with an audiologist to redo the sound system, so I suppose i'll spend the money to keep it running mechanically. :LOL:
It will be due for new oil in a few months, i'll get it all done at once then.
I suggest you use ZF oil/filter set.. gold standard..needs a good tech as its a complex two stage fill procedure and the filters can be trricky to get oil tight..
If you want to spend big money on audio I can advise!-:)
I've been using my current tech for 7 years, he is excellent. I have faith! https://www.autodoc.co.uk/zf-getrie...MI5LOoxtbBjgMV9ohQBh1ldyp4EAQYASABEgKHN_D_BwE
Is this the set?
Regarding the audio, my car is booked in at the end of August with Platinum in Car (https://www.facebook.com/platinumin.car/?locale=en_GB). The trophy wall upon entering was pretty immense :thumbsup:. It's going to cost £2k all in, which is pretty conservative as far as audio setups go, I believe, but it will include custom work to use the boot as the box for the sub, which will come out between the two front seats. He spoke about some more jargon which went completely over my head, something about AMPs and DSPs and tuning... I'm pretty excited!
I don't know the E89 well but I didn't think ZF made any dual clutch transmissions.
ZF make numerous dual clutch gearboxes…none were fitted to E89…Getrag no longer exists it was bought and merged into Magnya..
I quote ZF as if anyone knows how to service gearboxes they do..other suppliers are available…..but..it does appear that it’s not easy to get ZF filters…
Is this the set?
That’s the ZF 8HP auto box ..
Is this the set?
£2k fitted for a high end audio system is cheap…ish… but I’m sure it will be a big step up
