Hi everyone,
I recently bought a beautiful Monaco Blue E85, and while I absolutely love it, I've encountered a pretty alarming issue. Whenever I brake hard enough to activate the ABS, the rear left wheel completely locks up, no matter the speed, and stays locked until the car comes to a complete stop.
The first time it happened was terrifying—I was doing 50 mph on the motorway and had to slam on the brakes. The pedal went spongy, and that wheel just locked up. Otherwise, the car drives perfectly, and the brakes work fine during normal use. This issue only pops up during emergency braking.
I've had the car diagnosed multiple times, but no fault codes show up, and everything else seems to be in working order. To investigate further, my mechanic deactivated the ABS and tried to replicate the issue, but the wheel didn’t lock up this time, confirming that it’s definitely ABS-related. He suggested that the problem could be a seized valve in the ABS hydraulic module, possibly due to lack of use over time.
Now, I’m stuck deciding between two options: Should I buy a new ABS hydraulic module, or would it be better to have my current one repaired by a specialist? I’m particularly concerned about potential coding issues if I go the replacement route. Since no fault codes are showing up, it seems unlikely to be an electronic problem.
Any advice or experiences would be greatly appreciated!
Thanks in advance!
Thanks in advance!
