Bimmercode ??
q96169we said:
ori said:
So I’m going to invest in bimmercode as a Xmas present for myself.
Adapters I see the links on this thread, but is bimmercode available for iPhone?
Yes, it's available. I coded your car using bimmercode on my iphone, don't you remember? :poke: :poke:
You did indeed and it has held! I’m sure a software update might reset it, but still holding!
My adaptor arrives today and I will be coding the sound profile and start in sport individual mode.
So you’re pretty good with these things. What I would really like to code is remote start. I know American BMWs have the feature, but I heard you can code a limited feature. Think it requires someone with an FSC install and coding. Not something we can do.
Just to let you know. Coded so far:
New sound options b&w. (Haven’t tried music yet, but will see how it sounds)
Start on sports individual (tested and works a great)
Video in motion (not tried and doubt I will, but might be worth having for long trips to keep son occupied)
I believe you can code turn signals on head up display, but I haven’t found that and it might be in expert mode.
Curious as to how this works. If you have not got B&W amplifiers and speakers, how do you get the B&W sound. I am guessing you can't but you may get B&W software, can you enlighten me? Thanks
Effectively, you get the B&W custom equalization options, nothing more.
[ref]BeeEmm[/ref], it’s as above. You get B&W custom equalisation options and algorithms for the digital sound processing.
I have to say, it sounds good.
KrusteKlubba said:
I believe there is some sort of fake sound. Can’t remember what BMW call it.
Can this easily coded out with BimmerCode?
If you’re referring to “active sound design “ that “enhances” the engine and exhaust sound, yes it can easily be coded out. If you’re referring to something else, you’ll need to be more specific.
When I coded the B+W sound option, I also coded OUT the active sound, The car is so much quieter in the cabin now.. I don't need to hear the exhaust note to enjoy the car.... :driving: :driving: And it helps to make the music sound better... :thumbsup:
I use an MHD adaptor with my bimmercode / bimmer link app with IOS.
One word of caution though, i wouldnt code anything if you are under warranty with BMW, they are cracking down on this big time and it will show up straight away that its been tampered with!
Thanks ASD was what I was thinking. I’ve another year warranty left so will probably hold back any coding as BMW seem to be hyper vigilant on mods.
I'm not trying to persuade or encourge anyone to code their car. But based on my understanding, coding the car does not categorised as mods as everything is still within the design spec. If anything is outside the design spec, then those things won't even appear in the coding option.
I coded all my BMWs including mini. No issue with warranty so far (even when I code 2TB - Sport Auto to a non sport auto car then the gearbox threw some errors).
I wouldn’t tell anyone what to do, but coding with BMW is fine. in fact BMW code the car themselves if they need to code a replacement part in.
Not had any issues with them as they are car parameters.
Mapping on the other hand……BMW are cracking down hard on that.
That’s not the case so I wouldn’t be advising anyone it’s fine. If you are under warranty it’s your risk plenty of info about it all on the internet. Same with these “undetectable plug in tuning boxes” :lol:
Interesting as BMW dealership offered to use bimmercode to code stuff for me at the time I picked up my car.
In theory you can invalidate you warranty on a specific item. Say for example you coded the car to start in sport mode and it got stuck in sport mode. They could argue that you caused it. It’s a long shot for them as coding is simply switching on/off factory settings.
I’ve gone to my bmw dealership with my Carly readouts and the dealership has no problem with it.
I’ve coded all my bmw and never had an issue.
That said, you do at your own risk.
Found this info and it matched what I knew already.
Anyways, BMW arranges each individual option and its corresponding coding configurations, with a three or four digit character, at the factory.
So, say your vehicle has the Comfort Access feature, it would be saved, as one file, per se, as "S322" under the factory's vehicle order or VO.
VO coding means using a much more intricate program, to dig into the computer mapping and add or remove said features (as the factory did), via its "Vehicle Order" instead of using something like the Bimmercode APP, where alternatively, you make individual changes, to add or remove features.
Say I want to "VO code" in Comfort Access to my vehicle, that didn't come with it originally.
Instead of going into Bimmercode's "Expert mode' and make individual coding changes, to add/remove this option, I could instead "VO code" file "S322" and it would add/remove all those required coding changes, in one fell swoop.
The problem with the VO coding method is if a BMW franchise dealer ever has to do a software update or a new part integration, which is required, to complete and bill some warranty covered repairs. Incidentally, their system does a checks of your original "Vehicle Order" against any or our hypothetically, self-added "S322" option and detects any potential discrepancies.
It's not even a "gotcha" but more of a fail-safe and integrity check. So, by design, it would generate an error, which is a dead giveaway that you messed with the original vehicle order and programming.
But VO coding does give you a ton more flexibility and intricate changes, over the APP, which is its whole advantage.
With something less invasive like the Bimmercode APP, you don't actually add a file, (or i.e. VO code), you merely making changes, to a file that already exists, in the original vehicle order, so it doesn't trigger a mapping mismatch.
I hope this wasn't too nerdy and explained it a bit.
Please can you confirm what you mean by "Mapping" & is this relevant to using the Bimmercode app to make changes?
I'm paranoid about invalidating my warranty, but really want to make some simple audio changes (to reduce the exhaust sound internally) via the Bimmercode app.
BimmerCode can’t ‘map’….it can change some configuration variables within modules…I doubt very very much that those would be warranty violations ..
