Roof fault A696 Hall sensor
ClumUK
Post by ClumUK » Tue Jun 08, 2021 10:37 pm
RobbiZ4 wrote: Tue Jun 08, 2021 8:18 pm
ClumUK wrote: Tue Jun 08, 2021 9:11 am Maybe I just need to replace both?
Yes, you can. :D
But, if it's required, is not clear.
You can measure a bit with an ohmmeter:
~33k in one direction
~110k in the oposite direction, stepping down to 60k
These are the values of an dismounted part.
Well yes I'd rather not have to replace both :lol:
Just for my sanity this is what I'm seeing:
- Permanent fault on reader, and "Roof movement impaired" when pressing dash button with red flashing light:
A696 Hall sensor, open circuit, closing movement, rear-end module, Fault currently present, Fault currently not present
- I replaced with new the 1st hall sensor mounted at top of boot piston, long cable, yellow & brown wires, white connector. Still get the same error code & message as above:
- If I disconnect the 1st sensor I get different message, but still referring to A696:
A696 Hall sensor, open circuit, closing movement, rear-end module, Short circuit to negative
- If I disconnect the 2nd hall sensor mounted at bottom of boot piston, short cable, red & brown wires, black connector. Instead I get different code:
A691 Hall sensor, rear-end module open, Short circuit to negative
- Plugged the old sensor into the 2nd hall sensor black connector block. No change, only get the same A696 error as before:
Do you think this likely to be a faulty sensor, or rather a broken wire somewhere else in the harness?
2010 BMW Z4 35is (E89) - Deep Sea Blue Metallic
2016 Mini Cooper S - LapisLuxury Blue
1998 Toyota MR2 GT T-Bar Mk2 Rev5 - Orange Mica
2003 Honda S2000 GT - Spa Yellow Pearl
1996 Toyota Celica ST Gen6 - Lucerne Silver
Smartbear
Post by Smartbear » Tue Jun 08, 2021 11:24 pm
If you disconnect the sensor & get a short circuit to negative script, it sounds like a cable fault rather than a component fault.
e85 3.0si sold
RobbiZ4
Post by RobbiZ4 » Tue Jun 08, 2021 11:50 pm
ClumUK wrote: Tue Jun 08, 2021 10:37 pm Do you think this likely to be a faulty sensor, or rather a broken wire somewhere else in the harness?
Thanks for all the details.
From my experience, there should not be any wiring problem between the plugs of these 2 HS and the CTM plug. This is a very short connection with separated wires apart of the roof loom.
I will think about it tomorrow...
Pardon, je suis Allemand :oops:
:ant:
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
RobbiZ4
Post by RobbiZ4 » Fri Jun 11, 2021 6:46 am
Have a look at the following picture to get a better understanding:
I've done some tests with these hall sensors (HS) on my desk. The LEFT side of the ram directs to the front of the car (the description in red on the
picture is wrong!).
On the right coupling lock, there are 2 hall sensors mounted, each of the same type. The original mounted ones differ in it's wire colour as well as in the lenght of their wires. Spare parts will always be of the same part number as well as the wiring colour and lenght.
The left HS2 (assigned fault code A696) is repsonsible for the 1 second stop of the boot lid while closing, short before it reaches it's closed position.
The right HS1 (assigned fault code A691) is repsonsible to detect the open position of the boot lid.
:ant:
RobbiZ4
Post by RobbiZ4 » Fri Jun 11, 2021 7:14 am
Important link to correct fault code descriptions:
https://bmwfault.codes/
You have to select the line with the correct ECU variant!
:ant:
RobbiZ4
Post by RobbiZ4 » Fri Jun 11, 2021 7:52 am
Initial state:
ClumUK wrote: Tue Jun 08, 2021 10:37 pm - Permanent fault on reader, and "Roof movement impaired" when pressing dash button with red flashing light:
=> "HS-2"
ClumUK wrote: Tue Jun 08, 2021 10:37 pm - I replaced with new the 1st hall sensor mounted at top of boot piston, long cable, yellow & brown wires, white connector. Still get the same error code & message as above:
I assume, you've replaced "my HS-1" with a new one from stock?
Then this message is correct, as the initial fault code directs to the 2nd hall sensor.
Disconnecting a single hall sensor doesn't make any sense, as you add another fault. Only replacing a HS with a new or working one does help.
Can you provide a sharp(!) picture of the top of your original hallsensors, like the following one?
The red marked area is important.
:ant:
ClumUK
Post by ClumUK » Tue Jun 15, 2021 9:41 pm
Hi Robbie, thanks for all the detailed info! Yes you were right, I had replaced HS1 at first. Instead I replaced HS2 and then all was fixed :)
I had confused myself with my diagnosis of the error codes, just annoyed now as I cut off the old connector needlessly.
You can see in the picture the issue was probably caused by a cracked casing:
flybobbie
Post by flybobbie » Wed Jun 16, 2021 7:42 am
I bought two sensors and cylinder from local scrap yard, they were used on some Japanese or French car.
Close inspection revealed one had cracked.
I found i could test with battery and multimeter, the current changes through them on detection.
The cracked one worked fine.
I broke it open and inside is epoxy encapsulated sensor and magnet.
Must be this epoxy expanding and causing them to crack.
RobbiZ4
Post by RobbiZ4 » Wed Jun 16, 2021 12:39 pm
flybobbie wrote: Wed Jun 16, 2021 7:42 am I found i could test with battery and multimeter, the current changes through them on detection.
As described earlier, it's much easier to test even mounted on the car:
RobbiZ4 wrote: Tue Jun 08, 2021 8:18 pm You can measure a bit with an ohmmeter:
These are the values of an unplugged part.
:ant:
flybobbie
Post by flybobbie » Wed Jun 16, 2021 8:06 pm
When i tested on bench the best response i could get was the change in current.
Bhorton5357
Post by Bhorton5357 » Sun Jan 22, 2023 10:19 pm
Hi guys,
Sorry to flog an old thread but it seems the best place for this without going through all the rigmarole of starting a new thread and clogging the forum with multiple thread of the same issue.
Aquired my Z4 last summer from my dad who’s had it since it was 2 years old.
I’ve got the dreaded A696 code, I was wondering if anyone could shed light on which ram this sensor is located. Is it the ram for the clamshell/boot lid, or is it the ram that lifts the roof assembly out of the boot?
In addition I have a A692 for rear module closure microswitch. Is this the switch in the boot in the plastic bracket that the boot lid closes onto with the rubber bung?
This has happened after I had the car garages over most of the winter, so I’m assuming the issue with the sensors cracking due to the epoxy swelling must have something to do with either age, temperature, or a combination of both?
Again sorry for flogging a dead thread, appreciate any help
Ben
flybobbie
Post by flybobbie » Sun Jan 22, 2023 11:31 pm
Shrinkage on the wires causing breakage i have now seen on the wires to the brake fluid level switch.
Just where the wires enter the switch the insulation has shrunk and broke exposing the wire inside.
Bhorton5357
Post by Bhorton5357 » Mon Jan 23, 2023 12:23 am
Wires in the roof mech loom?
flybobbie
Post by flybobbie » Mon Jan 23, 2023 8:59 am
Yes in the roof too.
All my roof problems broken wires. The insulation seems to shrink and break.
Then eventually the unsupported wire inside breaks.
Reason why roof moves so far and stops or random bongs with roof closed.
All on the right side as there are more wires to go wrong and bundled tighter together.
I got fed up with them breaking, so only thing to hand was 13amp flex, i used the wires from that to fix.
Just need to go through forum to find fixes.
Bhorton5357
Post by Bhorton5357 » Mon Jan 23, 2023 10:58 pm
Thanks Bobby,
I’m going to have a look when I get a chance probably this weekend, I’ll post my findings, appreciate the reply
Ben
