Glovebox Removal/ Replacement
SPB9_Z4M
Post by SPB9_Z4M » Sun Aug 09, 2015 12:54 pm
Thought I'd post a quick guide on how to remove the glovebox as i took some photos while replacing mine at the weekend to fix a broken hinge. A relatively simple job, I know.
Steps:
1. Open glove box and pull the base of the piston out of the glovebox lid by squeezing the large tabs together.
2. Depress the two retainer clips such that the glovebox lid can fully rotate down exposing the fuse box behind and giving clear access to the screws required to remove the base of the glovebox. This requires pinching both clips simultaneously while pushing down on the glovebox lid to get it past the clips.
3. Unscrew 6 screws on the glovebox base. 2 at the back and 2 on each side.
4. Carefully pull/wiggle the glovebox assembly out. Note for models with a light there will be wiring attached for the light and light switch.
5. Remove the light by popping it through into the glovebox and then fit it back through its own hole (once reoriented).
6. Remove the switch by popping it into the glovebox and then unplug the connector to allow the wire the return through the hole for the switch. The part of the connector which disconnects is circled in red.
7. The wiring for the light and switch is attached to the glovebox with upholstery screws. I removed these by squeezing the cut out in the screw together and pushing back through the hole they're inserted in.
I then replaced the lid on mine and reversed the steps above to put it back in the car. I'm happy to explain further if anyone has questions on the lid replacement part.
Hopefully this is useful to someone. Cheers,
Present: Z4M Coupe | Black Sapphire | Black Nappa
Previous: Mini Cooper S (JCW body kit) Black
rj-ph
Post by rj-ph » Sat Aug 26, 2017 11:47 am
Sorry this is an old thread but has proved very useful. I have repaired the broken hinges on my glove box and now trying to re-install. I imagined that if I took the frame out I would be able to remove a hinge pin, offer the glove box back up and re-insert the pin. Unfortunately can't see how the pin comes out and have already broken one in the process. Any advice please?
2007 Z4 Coupé E86 Si Sport
rj-ph
Post by rj-ph » Sat Aug 26, 2017 12:50 pm
Cracked that problem in more ways than one. Did not realise that one of the pins has a little catch on it. Not obvious but I didn't take the whole thing out as instructed. Doh!!
Cir123
Post by Cir123 » Wed Oct 06, 2021 3:39 am
SPB9_Z4M wrote: Sun Aug 09, 2015 12:54 pm Thought I'd post a quick guide on how to remove the glovebox as i took some photos while replacing mine at the weekend to fix a broken hinge. A relatively simple job, I know.
Thank you so much!!! I hate that the easiest way to get to the relays is by taking out the whole glovebox :headbang:
Cir123
Post by Cir123 » Wed Oct 06, 2021 3:42 am
Is this removal applicable to a 07 Z4?
Cir123
Post by Cir123 » Thu Oct 07, 2021 5:29 pm
I'm attempting to remove my glovebox but I can't seem to find the retaining clips you're talking about nor the screws. I have an 07 Z4 E85
colb
Post by colb » Thu Oct 07, 2021 11:19 pm
Z Shed Cymru Founder All things Z3 & Z4
1999 1.8 Z3
