Tools needed:
New cup holder arm
Cross head screwdriver
Thin drill (1mm approx.) and thin screwdriver / nail to go though the hole made.
Pliers
Grease
Flat head screwdriver
Hammer
Approx 30 minutes
Step 1: Remove the vent / cup holder.
This is done by popping the cup holder open and removing the screw at the bottom and the screw in the top corner of the vent. Give the unit a tug and it will pop out:
Step 2: Dismantle the cup holder.
Remove the screw at the back of the vent unit, this will let you pull out the cup holder, it comes out through the front, so pop the cup holder out as if you were going to use it maneuver it out.
Snap the cup holder unit open along its edge and turn upside down.
At this point there is nothing stopping the two pieces sliding apart, but try not to let this happen as relocating this spring is a pain…
Step 3: Assess the problem.
If the arm has broken and looks like this, then this fix can help you, if not, Sorry, your on your own…..
Step 4: Pivot pin removal.
To get the arm out, you need to remove two pins, firstly the one holding the drop down part of the cup holder in place….
This is pretty straight forward and just knocks out with a little force.
The next pin, holding the arm in place, is a bit more tricky, it needs to be knocked out from the top, which means drilling a tiny hole, smaller the better above it and using a nail or small screwdriver to knock it out. Careful as there is a spring in the assembly and once the pin is out, it pings off…
Step 5: Collect the bits.
Pull the cam and spring out of the end of the arm. Retain these as well as the two pins you have just removed.
Step 6: Checks.
At this point its time to get your new cup holder arm, PM for details, and check that the cam arm moves in and out of the hole in the end, it is intended to be loose due to tolerancing of 3D printed thin wall parts. Check that the spring slips into the grove around the pivot pin and that the pivot pin itself is a good snug fit in the hole. It may be necessary to trim off any offending plastic inplaces.
Step 7: Assembly.
Stick some lubricant / grease in the end of the arm for the cam, and assemble the spring and cam shown here:
Now just push the assembly through the gap in the holder and ensure that the cam lines up with one of the groves inside the holder body and the spring pushes against the side wall.
Step 8: Pivot pin.
This is a little fiddly, but does work! Push the pivot pin through the hole in the bottom of the holder where it came out. You should feel the pin meet some resistance about half way in. Keep pushing it in until the assembly starts to feel solid. Cycle the arm through its range of movement a few times to check all has been installed correctly…
Now, and this is the fiddly bit, we have to get the pivot pin to go through the arm enough to fit into its location notch on the top face (where you drilled the tiny hole). The method I used was to slide a thin screwdriver between the top face of the arm and underside of where the tiny hole was drilled, to give a little extra depth for the pin. Once it is knocked into place and located in the notch, remove the screwdriver and it should be a good snug fit. If the pin doesn’t line up with this notch, the arm will wobble.
Replace the thin pin on the drop down section now that the pivot pin is in place. This little pin stops the big one coming loose.
Step 9: Test 1
The whole thing should work fine now. Apply some more lubricant / grease to the internals near the cam and its track.
Step 10: Reassemble and reinstall
Shouldn’t have to explain this one, just put it back together and screw it back in to the car!
Step 11. Test 2
Turn on ignition, put drink in cup holder, go for drive.
