BMW Error code 20 70 28 ?
Simn
Post by Simn » Sun May 25, 2014 3:53 pm
Can someone tell me what does it mean? I tried to understand but without luck, please help!
  • 2012 - 2015, 2.5i 2003 Sterling grey, convertible
    2015 - , 3.0si 2006 Black, Coupe
[/size]
Simn
Re: BMW Error code 20 70 28 ?
Post by Simn » Sun May 25, 2014 7:34 pm
Come on!
[/size]
sammysquid
Post by sammysquid » Sun May 25, 2014 7:48 pm
did you read..
http://translate.google.co.uk/translate ... 6bih%3D977
seems to be some problem either with seat occupy thing or left pillar harness?
their code is slightly different but I would think you are looking at a wiring fault on one of your airbags...
Simn
Post by Simn » Sun May 25, 2014 7:57 pm
sammysquid wrote:did you read..
But this guy got "Error Code: 20 70 FF" not really the same?
[/size]
sammysquid
Post by sammysquid » Sun May 25, 2014 8:16 pm
you're right.... they aren't "really" the same... but that is the only real reference i found and wondered if you had read it, it is only slightly different and i would be inclined to see if i could start from there
Do you want to provide some more information? Were you doing anything when the code started? have you tried clearing and how quickly does it return?
I mean the obvious answer is to go to bmw and see what they say...
Simn
Post by Simn » Sun May 25, 2014 8:28 pm
sammysquid wrote:you're right.... they aren't "really" the same... but that is the only real reference i found and wondered if you had read it, it is only slightly different and i would be inclined to see if i could start from there
Sorry im getting realy pissed off by this car now :headbang:
I got a 2.5 2003, and I changed to a multi functional steering wheel, I did follow this guide http://www.z4-forum.com/forum/viewtopic ... 26&t=16422.
I was stupid and turned to ignition on when the airbag wasnt connected.
I bought a bypass occupancy sensor and tried to reset with INPA but still light ON.
My car was manufactured after 09/03 so I had to do like this, maybe something is wrong with the cords?
[/size]
sammysquid
Post by sammysquid » Sun May 25, 2014 8:48 pm
Have you checked with a multimeter to check that the scotch lock is making good contact? I personally never like them, but that would be my first point of call.
Then I think I would want to try and put it back to standard and clear the error.... and then start again and check that it is something simple..
What was your reasoning for buying a bypass occupancy sensor?
Simn
Post by Simn » Sun May 25, 2014 9:00 pm
sammysquid wrote:Have you checked with a multimeter to check that the scotch lock is making good contact? I personally never like them, but that would be my first point of call.
Maybe I should check with a multimeter. But the controls work.
I tried indeed to change back to the original steering wheel, but the cords were still taking electricity if u understand what i mean (like the picture i added).
I bought the bypass because i thought i broke the sensor pad in the passenger seat and that was why the airbag light was on.
[/size]
sammysquid
Post by sammysquid » Sun May 25, 2014 10:02 pm
So have you removed the bypass? just to reduce possible issues.
The controls though are separate to the airbag leads, have you tested the airbag leads? obvs have the battery disconnected and check for continuity rather than testing voltage. I don't think the steering controls would be related so whether they work or not isn't an issue. it is the airbag connection that would bother me, have you checked it is seated in properly?
Again make sure you follow the normal procedures!
Did you use your original airbag ?
sk93
Post by sk93 » Sun May 25, 2014 10:15 pm
scan the actual satellite modules, rather than just getting the overall error.
they'll tell you exactly what the cause is, rather than just giving an ambigious error code
(in INPA, select safety, and then select the "satelline B pillar" modules - read the error codes stored in those and post up what they are.
You can also test the seat occupancy sensor in INPA.
Again, goto the satellite B pillar modules, goto "status" and then click "seat".
you can see a live feed from the occupancy sensor there.
just dont go into the "activate" menu. I've never gone there myself, but it doesn't take a genious to work out what that COULD do :thumbsup:
:zzzz:
Simn
Post by Simn » Mon May 26, 2014 7:18 pm
[/size]
Simn
Post by Simn » Mon May 26, 2014 8:48 pm
I took off the scotch lock and installed the old steering wheel and tried to reset it with INPA but without sucess.
The airbag light is still ON. I tried with the old steering wheel + bypass module and still ON.
Now everything is back to original and light is still ON when Im trying to reset.
It must be the slip ring? Is there anyway i can see if the slip ring is broken?
[/size]
sk93
Post by sk93 » Tue May 27, 2014 12:02 am
you need a newer version of INPA... 5.0.2 is a good version for our cars.
have a google for "bimmerpost INPA update" and you'll find all you need :thumbsup:
seriously, without knowing the "real" error, you'll be stabbing in the dark for days..
:zzzz:
Simn
Post by Simn » Tue May 27, 2014 11:19 am
sk93 wrote:you need a newer version of INPA... 5.0.2 is a good version for our cars.
Gonna try get the right version of INPA later
Tried Carsoft, this was the results (still light ON :| )
[/size]
sk93
Post by sk93 » Tue May 27, 2014 12:12 pm
No idea about carsoft -never used it.
Let me know how you get on with INPA - once you get into the satellite "B" pillars and can read their error information, we'll honestly have something decent to work on!
:zzzz:
