Hows the best way to remove these?
Most posts say to use a screwdriver to lever off, but from which angle, and how big a screwdriver?
Have had a go but dont seem to be getting very far, and dont want to damage anything.
Removing Side Air Vent Screw Cap Covers
- srhutch
- Moderator
- Wondermike
- Moderator
Re: Removing Side Air Vent Screw Cap Covers
Try a knife from your cutlery set instead, they come off pretty easily once you catch them right.
- srhutch
- Moderator
good idea, I always use a dinner knife to get the centre vent out, works much better than a screwdriver.Wondermike wrote:Try a knife from your cutlery set instead, they come off pretty easily once you catch them right.
- srhutch
- Moderator
Cracked it!
Used a Flat Bladed Precision Screwdriver, the trick is not to try to lever up the scre as well.
The cap has no retaining lugs, it just an interference fit, so you need to just push the screwdriver only the lsightest amount to get it to pop off.
I will post a pic of the unside of the cap in the next few days so that it helps other members if they are trying to remove also.
- ZetaTre
I have removed several of them and never managed to get them off intact. They are about 50 cents a piece, so the damage is limited.
2003 Z4 2.5i
2004 X3 3.0i
2002 Ducati Monster S4
- pvr
I assume that is the dash project. Done the hole cutting yet?
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
