Roof Liner Front/Rear - Removal and Reinstallation
How-To articles are in here.
Z4_Gaz
Post by Z4_Gaz » Fri Aug 30, 2013 11:08 am
The following info relates to the removal and reinstallation of the Roof Liner on E89 Models.
1.Special Tool
2. Front Liner
3. Rear Liner
Maniac
Re: Roof Liner Front/Rear - Removal and Reinstallation
Post by Maniac » Fri Aug 30, 2013 11:09 am
:thumbsup:
flybobbie
Post by flybobbie » Thu Mar 19, 2020 9:31 pm
I fancied applying some noise insulation on the roof. Sounds like cheap tin when it rains.
colinv
Post by colinv » Mon Mar 23, 2020 11:01 am
Hi how did you access the pictures please
tintoverano
Post by tintoverano » Mon Mar 23, 2020 11:15 am
colinv wrote: Mon Mar 23, 2020 11:01 am Hi how did you access the pictures please
right click over them -> open in new tab
mSport 23i
Coding Help, Stubby, Remap, K&N filter, Cruise Ctrl, Reverse cam, Instrument Cluster Color, UR front brace, CDV delete, Android on CIC, Roof Module, LSD
flybobbie
Post by flybobbie » Tue Mar 31, 2020 8:33 am
I was put off messing with the roof liner as some other instructions i read said that the roof liner would be damaged when removed.
RobbiZ4
Post by RobbiZ4 » Tue Mar 31, 2020 8:45 am
Pardon, je suis Allemand :oops:
:ant:
E89 Roof Maintenance
viewtopic.php?t=130932
Y3 Roof Diagnostic System
viewtopic.php?f=23&t=129048
Phil40
Post by Phil40 » Wed Feb 03, 2021 7:42 am
Hi team
Can i ask please the name of software where screenshots are taken ?
Thanks ;)
E89 2011 Sdrive 23i manual Sapphire Black - France (sorry for my english level not perfect) ;)
flybobbie
Post by flybobbie » Thu Mar 04, 2021 9:45 pm
Had my roof liner off, fairly straight forward.
Need to push down rear corners first, easier with the rear window up over the top.
Then slide your hand in carefully between liner and metal roof and push down
You can sort of feel where the poppers are.
Start here:
