Remove E85 kidney grille
- marypoppins
Have seen the BM bulletin with reference to removing these however they seem very reluctant to budge when following the instructions. Any tips as i dont want to break them?
2.0i sport Sapphire black,sports seats,wheels,bluetooth prep, folding mirrors blah blah.
- markeg
Re: Remove E85 kidney grille
They should just pop out, unless someone's added so additional "fixing"? I just ease mine out from the top left-hand edge, and then work my way round.
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- Swiftly
As markeg has said, mine also just pop out, infact a tad too easy really
- andysat
I was in the same boat as you -just sprayed wd40 (don't know if it helped but seemed to).
Gone but not forgotten.
New ride silver e93.
- srhutch
- Moderator
- Bing
This is how I do it. The 'pull' needs to be a decent yank. They won't breaksrhutch wrote:Hold two of the slats at the bottom and then lifting slightly pull.
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
Now you've said that they will break!Bing wrote:This is how I do it. The 'pull' needs to be a decent yank. They won't breaksrhutch wrote:Hold two of the slats at the bottom and then lifting slightly pull.
I thought the same though when doing mine, just closed my eyes and gave it a good yank and came out fine
Titanium Silver Z4 ///M Coupe
- Stuart Truman
+2 lift it up with a reasonable pressure and it shouldn't be too tough to pull out. Certainly not enough to break it. If it doesn't pull, don't force itBing wrote:This is how I do it. The 'pull' needs to be a decent yank. They won't breaksrhutch wrote:Hold two of the slats at the bottom and then lifting slightly pull.
Add yourself to the Z4 Map HERE! Instructions HERE!
Z4M Roadster, Imola Red, with Stubby and Intravee II. Low Miles per Gallon, High Smiles per Gallon
Previously Alpina Roadster S #69 Alpina Blue
