**** The Definitive Rattles Cure Guide ****
Mafoo
Post by Mafoo » Fri May 04, 2012 9:06 am
As fellow Z4 owners you are probably well away of the variety of rattles around the car that we suffer day to day.
I thought it would be good to start a thread that pulled the various "ailments" together as a definitive how-to.
Lay the problem out as follows:-
1. Location
2. Issue
3. Problem
4. Solution
I will start it off......
Location - front bulkhead (E85)
Issue - metallic vibration when driving over speedbumps.
Problem - engine bay stabiliser bar bolts slightly loose
Solution - Tighten stabiliser bar bolts.
Bit like NHS direct for a Z4 really :roll:
Matt
Sent from my GT-I9100 using Tapatalk 2
Z4 3.0i SE - gone but not forgotten
Need a Forum approved Specialist Independant Garage? viewtopic.php?f=4&t=38928
wantanM
Re: **** The Definitive Rattles Cure Guide ****
Post by wantanM » Fri May 04, 2012 11:46 am
Great idea
Location: as if it was coming from the dash or steering column
Issue: f***ing annoying. A strange "creak" on a low speed corner that was also a sudden up gradient, ie an entrance to a car park
Problem: front firewall strutbaces. Blots slightly loose. Unable to detect this by hand/eye/or waggling. Only with torque wrench.
Solution: re- torqued to 35Nm. (no more - very careful not to overtighten it is possible to shear bolt!)
Much loved Z4MC
Stromtech
Post by Stromtech » Fri May 04, 2012 3:33 pm
Annoying squeak behind your head when the hood is down.
It' could be caused by the center panel above the storage compartment:
http://www.zpost.com/forums/showthread.php?t=389322
2004 3.0i 6 speed, Sterling Grey, Premium, Sport and Convenience packages
srhutch
Moderator
Moderator
Post by srhutch » Fri May 04, 2012 5:06 pm
Location, front passenger seat
Issue, irritating noise
Solution, leave wife at home next time. :lol:
Sorry had to be done
andysat
Post by andysat » Fri May 04, 2012 5:10 pm
srhutch wrote:Location, front passenger seat
:rofl:
Gone but not forgotten.
New ride silver e93.
wantanM
Post by wantanM » Fri May 04, 2012 5:11 pm
too easy...
Much loved Z4MC
jaRED
Post by jaRED » Fri May 04, 2012 5:41 pm
[quote="srhutch"]Location, front passenger seat
Outrageous!!
Redzed coupe gone but not forgotten :? , Lotus Evora providing the smiles now :driving:
Bing
Post by Bing » Fri May 04, 2012 5:49 pm
Stromtech wrote:Annoying squeak behind your head when the hood is down.
I have this squeak !! Been driving me mad so I'm delighted there is a fix... Except the key pic showing exactly what to do where is missing :headbang:
Guess I'll just have to figure it out myself :?
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin 8)
Bing
Post by Bing » Fri May 04, 2012 5:53 pm
1. Location - windscreen wipers
2. Issue - squeak when in use, usually at the end of a sweep
3. Problem - no idea...
4. Solution - lubricate every joint of the mechanism, including those on the wiper blade itself, with small amounts of 3-in-1
When it comes back, repeat :roll:
T2FFN
Post by T2FFN » Fri May 04, 2012 6:07 pm
The wiper squeek is an issue abd can lead to the joint snapping off. My last Z4 did this, then it broke so driver arm didnt move. I have an old post on this, its an expensive fix if you go oem as you have to replace the whole thing.
I welded on a new ball joint. Search for wiper issue, i put pics up. My current Z4 has the same squeek, i will get to properly lubing this one to avoid it snapping.
Sent from my Desire HD using Tapatalk 2
3.0i
srhutch
Moderator
Moderator
Post by srhutch » Fri May 04, 2012 9:15 pm
Bing wrote:1. Location - windscreen wipers
When mine did this he dealer replaced the motor and linkage assembly and it still did it so replaced the drivers side are and fixed the issue.
I will lube the pivot on the arm on my current car and see if it fixes the exact same noise I had on the previous car. I will report back.
spearman
Post by spearman » Fri May 04, 2012 10:22 pm
Mafoo wrote:As fellow Z4 owners you are probably well away of the variety of rattles around the car that we suffer day to day.
1. Location
2. Issue
3. Problem
4. Solution
Matt
Matt, great idea! Any pics of the bolts in question/location? This has been annoying me for a while and your post describes the exact issue! Sounds like a quick fix.
2008 ///M Roadster
corsaire77
Post by corsaire77 » Mon May 07, 2012 6:13 pm
middle panel rattle
- the plastic panel below the HVAC
Issue:
- squeaks, especially on cold days
Solution:
- remove it with a flat head screwdriver and line the inside edges with double-sided tape
corsaire77
Post by corsaire77 » Mon May 07, 2012 6:16 pm
Cupholder rattle
Location - the cupholder
Issue - rattles/squeaks
Solution - line the panel with foam (panel squeak)
Solution - the inner end of the cupholder has a tightening torx screw - it's either missing or not installed during the retrofit.
corsaire77
Post by corsaire77 » Mon May 07, 2012 6:25 pm
Dash rattle - LHD cars, RHD should be the mirror opposite
it seems to be the airbag, the steering column, the instrument cluster, or the cupholder
it actually is BEHIND THE HEADLIGHT SWITCH
Issue:
A hollow plastic knocking sound when driving across bumps
Solution:
1) remove the instrument panel
Attack the torx screw with a T20 key, gently pull the cluster, no need to disconnect the wire.
2)
reach into the hole and move the headlight switch assembly up and down - it will rattle as the plastic bolt in the rubber hole is loose.
Take a flat head screwdriver, cut a piece of foam or double-sided tape, and squeeze it deep into that hole with the tip. Move the headlight switch assembly - it should be stable.
3) gently reinstall the instrument cluster
