Replace BMW Emblem on Bonnet
How-To articles are in here. Please use sub-forum for requests
ksher
Post by ksher » Thu Sep 01, 2011 6:57 pm
How to safely remove the old emblem on the bonnet? Thank you.
Current BMW: 640d Gran Coupe M Sport (F06), 118d SE (F20).
Previous BMW: Z4 sDrive23i M Sport (E89), 318i Sport (F30), 120d SE (F20), Z4 2.5i Sport Roadster (E85), 523i Sport (E60), 323Ci (E46), 523i SE (E39), 318i (E36).
ksher
Re: Replace BMW Emblem on Bonnet
Post by ksher » Sat Sep 17, 2011 6:42 pm
Any advice? I have already tried floss and pry bar, the emblem did not come out even a bit. :(
cj10jeeper
Post by cj10jeeper » Sat Sep 17, 2011 6:53 pm
Is it fastned in the same as the the E85 where you pull the grille out and undo a couple of self tapping nuts on the rear of the badge that hold it in on 2 plastic legs?
ksher
Post by ksher » Sat Sep 17, 2011 7:03 pm
The new emblem I have has 2 pins (2 cm long) at 3 and 9 o'clock positions, and 1 pin (1 cm long) at 12 o'clock position. I don't know how it works on E85.
cj10jeeper
Post by cj10jeeper » Sat Sep 17, 2011 7:06 pm
Then it sounds like the old model. I'd remove one grille and feel under the bumper cover where the back of the badge is (or whatever else you have to remove to get to the badge) and bet you'll come across a couple of retaining nuts on the longer pins.
ksher
Post by ksher » Sat Sep 17, 2011 7:09 pm
cj10jeeper wrote:Then it sounds like the old model. I'd remove one grille and feel under the bumper cover where the back of the badge is (or whatever else you have to remove to get to the badge) and bet you'll come across a couple of retaining nuts on the longer pins.
Thanks. CJ. Please see picture below.
cj10jeeper
Post by cj10jeeper » Sat Sep 17, 2011 7:13 pm
They look like pins that would work with self tapping nuts and the third as a locating pin (well someone might try to fit it upside down??)
BTW - you need to get your wife to iron tha tablecloth...
AlanJ
Post by AlanJ » Sat Sep 17, 2011 7:22 pm
Two nuts hold this on. Part Number 51418176418
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
ksher
Post by ksher » Sat Sep 17, 2011 7:38 pm
cj10jeeper wrote:BTW - you need to get your wife to iron tha tablecloth...
It was just the wrapping paper. :D
ksher
Post by ksher » Sat Sep 17, 2011 7:43 pm
AlanJ wrote:Two nuts hold this on. Part Number 51418176418
Thanks, Alan. This is why the normal way of removing the emblem wih pry bar did not work on Zed. :headbang:
Can the nuts be re-used after they are released?
ksher
Post by ksher » Sun Sep 18, 2011 9:39 am
I have removed the air dust to get access to the inside of the bumper (easier than removing the front grill). The emblem on E89 is also secured by 2 retaining nuts.
But other US and Canadian E89 owners said the emblem in Europe is different from what they have over there.
I don't have the socket small enough to loose the nuts (< 8mm). :headbang:
AlanJ
Post by AlanJ » Sun Sep 18, 2011 10:57 am
Not sure - if they are simply 'metal' nuts that cut there own thread into the plastic I'm sure they can.
cj10jeeper
Post by cj10jeeper » Sun Sep 18, 2011 12:11 pm
If the pegs on the badge as plain and tapered then it will be reusable self tapping nuts.
Tacky things stows out of sheet metal
ksher
Post by ksher » Sun Sep 18, 2011 12:23 pm
Thanks, CJ and Alan. A new emblem is now on the bumper.
