Checking offset numbers before purchase
Alloy wheels and tyre discussion
Pagan
Post by Pagan » Thu Oct 31, 2024 9:17 pm
Hello, I’m just about to pull the trigger on some new wheels for my Z4 E85. I’ve plugged the numbers into the usual sites, and they seem okay, but I’d really appreciate double-checking that these are right (especially offset):
Front: 18x8.5” ET38 (probably with 235/40 tyres)
Rear: 18x9.5” ET40 (probably with 255/35 tyres)
I’m looking to have the wheels a little further out than stock but nothing too extreme, and I definitely want to avoid rubbing. I probably will be putting in some slightly sportier coil springs (30mm drop).
Thanks.
RMB
Post by RMB » Thu Oct 31, 2024 9:29 pm
Which car?
2006 E85 2.5i manual, Montego Blue “Monty”
2017 F22 M240i Estoril Blue “Mr Z”
2009 E82 123d. Space Grey. “Turbo Bus” Gone
2004 E46 M3. Vert. Silver Grey. Gone.
2003 E46 330ci. Mystic Blue. Gone
Pagan
Post by Pagan » Thu Oct 31, 2024 9:51 pm
E85 (non-M), thanks. I've edited the original post to include this.
j3nks79
Post by j3nks79 » Sun Nov 03, 2024 12:44 pm
I run a rear 18” 10J ET40 with 255/35 zero problems.
Fronts 18” 8.5J ET35 with a 225/40 zero problems
2009 09 Carbon Black Cinnamon E86
darich
Post by darich » Wed Nov 20, 2024 11:18 am
My wheel and tyre sizes
Rear
255x30x19
9.5x19 39ET
Front
235x35x19
8.5x19 35ET
E86 M Sport with standard suspension.
No issues
Previously 2004 Sterling Grey E85 3.0SE
Currently 2007 Silver Grey E86 M Sport
Instagram - Zed4Coupe
Zedebee
Post by Zedebee » Wed Nov 20, 2024 12:58 pm
They aren’t “right”, i.e. they are not the OEM sizes/offset, but they should be fine.
Zed no.5
RossT
Post by RossT » Fri Jan 17, 2025 3:11 am
Hi Pagan, were those Enkei wheels you were looking at?
I only ask as the sizes and offsets look very similar to a few designs I've been considering! Did you go ahead in the end?
Pagan
Post by Pagan » Fri May 30, 2025 7:42 pm
Hey Ross, it was JR actually. I've purchased but not yet fitted!
RossT
Post by RossT » Sat May 31, 2025 6:12 pm
Pagan wrote: Fri May 30, 2025 7:42 pm Hey Ross, it was JR actually. I've purchased but not yet fitted!
Ah, thanks for the reply. Would like to see some shots once you get them on, I love wheels!
