Car: E86 Coupe N52 Engine
Symptoms:
All dashboards lights are fine, headlight indicators work, horn radio works etc
Turn the key and nothing happens.
No codes being found on a Creator C310+
Battery is good.
The lead up to this point:
the car had started to become a bit lethargic to start, so a new starter motor was bought at the start of the year.
Couple of weeks ago car had been out for a run. Came home, switched it off, then tried to turn back on again.
Heard a few clicks and nothing happened.
I installed the new starter motor.
Both red positive and black negative cables securely reattached etc.
Still nothing.
Then I thought it might be the ignition switch.
Bought a cheap one to se if that was the problem, installed it and still nothing.
Before I call the RAC to get them out to take a look, has anyone any suggestions?
thanks
Symptoms:
Battery is good.
Still nothing.
thanks
