Run flats
Run flats
After seeing a vast amount of posts strongly suggesting you do away with the ridiculously hard run flats, I've gone and replaced with a fresh set of non-run flat tyres, and WOW!!!! I see what all the talk was about, the difference is like night and day!!!
- buzyg
Run flats
Welcome to the light.Steham wrote: Thu Feb 15, 2024 11:08 pm After seeing a vast amount of posts strongly suggesting you do away with the ridiculously hard run flats, I've gone and replaced with a fresh set of non-run flat tyres, and WOW!!!! I see what all the talk was about, the difference is like night and day!!!
Run flats
I run non rft's GY asym, 18 inch, 38 front also 38psi rears. Rft rear was recommended 42 on a 23i, but too hard, tyre crown wears and a bit jumpy.
MOT station checked wear and was even across all tyres.
They even adjusted my headlights, up.
- RobbiZ4
Run flats
Your 38 front on 18s is 2 above the maximum on the B pillar of my 35iS.flybobbie wrote: Fri Feb 16, 2024 9:25 am I run non rft's GY asym, 18 inch, 38 front also 38psi rears. Rft rear was recommended 42 on a 23i, but too hard, tyre crown wears and a bit jumpy.
Your 38 rear is 6 below.
Vidi, vici, veni
