Starter Motor location on E86 3.0
- chanlon1
So fairly sure my starter motor is on its way out.
Had a look in the engine bay to get a feel of how easy/difficult it would be to change.
Being stupid, I couldn't see anything that looked like a starter motor
All the pics and videos I have seen have been on other Z4 engines, not the 3.0L.
People suggest using a hammer to tap the motor to see if that helps....but I have no idea what to tap.
Anyone able to describe/link to a photo/video etc?
thanks
thanks
E86 Z4 Coupe 2006 Silver
Same place in all the M54 and N52 variants, left hand side of the block under the inlet manifold, towards the back of the engine where it meets the gearbox housing. Difficult but not impossible to see. Also difficult but not impossible to replace without removing major components, although it’s more by feel than direct line of sight.
You won’t be able to tap it with a hammer directly, but a strategically placed length of wood or breaker bar should reach it.
2003 Maldives Blue 3.0i auto
- Rockhopper
Left hand side means as you are sitting in the car, if you are standing infront looking at the engine it’s on the right hand side.
- MikeyH
Much easier to remove on the 2.2 luckily as mine went shortly after I bought it. It comes out from the top without removing anything but on yours you will have the sound generator in the way.
- pvr
There is a good detailed thread on here for the 3.0si without removing components
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- chanlon1
I think I found that thread as it talked a lot about doing by feel rather than sight.
On a scale of 1-10, where does the difficulty sit?
I know you have three bolts to remove and a plastic connector, but are there any other complications etc?
- chanlon1
- pvr
Yep
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- chanlon1
I was sprawled over my engine bay earlier with a torch to see if I could match what I was looking at, with what was on the video. I mustn't be looking hard enough cause the only "snap" that was happening were my limbs
I need to revisit it again and maybe look at seeing if I can remove the sound generator to give a bit more space. If I dont know what I am looking at or for, I'm sure as hell not going to put a ratchet down there and start unbolting whatever nut comes to touch first
Is the replacement feasible from below?
- MikeyH
It is not that easy to see even without the sound gen, you need to look quite low down by the clutch housing. It's I think black and has 2 small wires coming out the back and one thick one.
- pvr
Well, my Z is in the air so I am attacking that either from below or from the top. I won’t be laying on top as that is a bit high from the floor
I have the new one ready to go in though
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- chanlon1
Paul, two questions.
1. What make of new starter did you go for? Any links etc.
2. Let me know if you think it can be tackled from underneath. It’s another week or so before I’ll have the car on a proper ramp, so interested to know.
- pvr
I got it from autodoc as it was impossible to get the recommended units from anywhere as all sold out.
Part number dsn1375 (Denso)
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- pvr
Just had a look underneath but need to remove the under cover to see what I can get at. Not at this time of night and the car next to it has been dropping a fair bit of rainwater that has run onder the Z so need to hover that up tomorrow
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- chanlon1
Thanks Paul, let me know if you find anything underneath. I’ll take a look at sorting out a new unit from AUTODOC shortly.
